- Solder sometimes fail with constant vibration.
- Butt connector is bullet-proof, if done correctly.
- If you don't believe me, do a Google search using key words "car wiring butt vs soldering"...
2006 v70r iginition wires
- Has thanked: 1507 times
- Been thanked: 3823 times
Unless you are driving a Tesla in space, a good NASA solder splice is designed to withstand **some vibration***
- RickHaleParker
- Been thanked: 958 times
The latest thing in "Butt connectors" produces ... gasp... a solder joint.
If solder joints where inferior, why would the "Butt connector" manufactures be going down this path ...
A solder joint spreads the stress from vibrations over a larger area. With a Butt connector all the stress is concentrated at the crimps, which are under stress to begin with. Think about it, butt connectors always fail at the crimp ... put two and two together.
[youtube][/youtube]
[youtube][/youtube]
- 18 Replies
- 2783 Views
Last post by joe_pinehill
- 808 Views
Last post by coflynn
