Hello all,
The oil light on my car comes on and off. Is this something I need to worry about? Any suggestions? Thanks in advance.
2000 S70-The oil light comes on and goes off
neworleans
- Year and Model: 2007 S60R
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
Have you checked your oil? Does it come on randomly or is there a distinctive pattern? Could just be a malfunctioning liht or sensor, or you could have a legitimate problem with low oil pressure. How many miles are on the car?
Knows enough to be dangerous
neworleans
I actually recently got the car but the light wasn't on when I test drove it.
The oil looks dirty, I was going to change it today but wanted to ask you all first for any tips.
I read somewhere that some seals inside the oil pan usually go bad.
The car has 69K miles on it.
I also noticed some oil leak on the back side of the pan like below, I cleaned it today and will drive some tomorrow and check again to locate the leak if I can.
- Has thanked: 1611 times
- Been thanked: 4071 times
Check the level first, then change it. That light is the only thing between you and a $3000 enginejob.
I have the same seep on my 99, I’ve washed it down, tightened the oil pan bolts, replaced the oil cooler bolts. But still have the seep , apparently showing at the oil pan/ blockjunction
I use about 1 liter in 2500 miles
neworleans
- 850 LPT
- Has thanked: 335 times
- Been thanked: 247 times
You must be seriously low on oil before that light comes on, to a point were you don't see anything on the dipstick. If that's the case you are missing 3+ quarts. Once you get that oil change done the light will go out.
Did you check the dipstick?
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
Leave the oil cooler alone, get the oil changed and full, then wash off the rear (right side) of the engine to track the leak
Im not sure your cooler is leaking.
- Has thanked: 2207 times
+1 with abscate on this one. In your first picture you can see oil as high as the pipe (I think it is the oil return pipe from a turbo possibly). So not convinced on the source. Is there oil around the oil filler cap on the top of the motor? It could be as simple as the oil filler cap seal needs replaced, or maybe the PCV needs serviced and oil is running down the back of the motor. There are a couple of drains from the spark plug cavity below the cover plate. Remove that and check if cylinder #2 + #3 have oil around them.
Also check the oil cooler lines on the turbo are not rusted through or leaking.
jimmy57
- Has thanked: 5 times
- Been thanked: 322 times
The oil light behavior can be either that the engine does have low oil pressure at times due to weak oil pump, leak in the o rings in oil filter housing to oil pump, or oil passage between engine and the oil pan. The oil pressure switch can fail make the light come on when oil pressure is not a problem. The oil pressure switch is on the front of the engine in almost the same relative position as the pipe on rear of engine above the oily area. Have you looked there to see if there is any leakage? The oil pressure switch has a single wire and if it fails and makes the light come on it is common to have the switch leak.
neworleans
Thank you all, I am going to check all that tomorrow and let you all know.
I was planning to put this engine flush additive before the oil change, do you all think it is a good idea?
"Liqui Moly 2037 Pro-Line Engine Flush"
- 798 Views
- 10 Replies
- 1684 Views
Last post by SuperHerman
- 24 Replies
- 14741 Views
Last post by chrism
- 910 Views
Last post by GreenMagicMan
- 10 Replies
- 1988 Views
Last post by vtl
