RADIO CODE '91 940 GLE
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
CarlD trimagna
Post by CarlD trimagna »
In swapping batteries, I managed to lock the radio - the display reads OFF.
I now have what should be the correct 6 digit code.
I tried to follow the procedure in the manual, leaving the radio connected for at least one hour.
So far, I can't reset the radio to enter the security code.
As I understand the manual, I am supposed to leave the radio connected, meaning the battery connected, the ignition off and the radio knob turned off, for at least one hour.
After seeing the CODE message, I enter the code then press the AU button (above the CD button).
If I am missing a step or if there is a better process, I would appreciate any and all help.
Regards,
- CarlD [email protected]
potroast
Year and Model:
Post by potroast »
have you already entered the incorrect code a few times? If you lock the radio out, you will need a new radio.
CarlD trimagna
Yes, I may have entered the wrong info enough times that the radio is locked. However, the OFF message should be resettable, according to the manual.
What is your source of information to indicate that it is not resettable?
potroast
Year and Model:
Post by potroast »
personal experience. If you enter it enough times (between 3-5) then you will lock the radio... That's the point of the code. Once locked out, you'd need to at least send the existing unit back to the factory to have certain components replaced. You'll find it much more cost-effective to use an aftermarket unit, if this is the case.
Take it to the dealer, and see what they say.
Biut if you have locked it out, then you will basically need a new unit.
harvey
Post by harvey »
Yor volvo main agent will supply code - see rely I gave earlier
