Timing belt questions
mrjay62
Year and Model: V70XC 2002
Been thanked: 3 times
Re: Timing belt questions
Post by mrjay62 »
Thanks Abscate.
That's way different.
I'm thinking I may have bent that line I can get it close by not close enough to start a bolt or without the heat shield touching the pipe.
Got a back up pipe and more copper washers , orings... going swap them while it stopped raining... grrr
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
mrjay62
Post by mrjay62 »
Thanks Rick..
I figured out how it goes back together but the pipe is in the way....
Need batteries its almost out...lol
Has thanked: 1505 times
Been thanked: 3818 times
I think it slips under the pipe.
mrjay62
Post by mrjay62 »
Yes it does go under the pipe...
But not to name names Some Dumbass some how bent the pipe! Someone with the bright idea to remove the head with the manifold attached!
Grrrr. Pipe replaced and it now fits just as it should....
Thank guys.
DA.
BlackBart
Has thanked: 927 times
Been thanked: 884 times
Post by BlackBart »
You're patient and perseverant, Mr DA, and that's all that matters.
mrjay62
Post by mrjay62 »
lol thanks...
So far this is where I'm at...
Taken a little break and I'll get back at it....
BlackBart
Post by BlackBart »
Did you powder coat that cam cover? It gleams!
Just a question about working outside......it sucks, I understand. Would one of those big square collapsable tent canopy things provide enough cover for you? This amazing guy in Seattle did an entire 122 wagon body swap in his driveway using a folding canopy.
mrjay62
Post by mrjay62 »
Hey BBart.
No powder coat, bead blast VHT primer and VHT cast aluminum paint....
Its what I do when I can't do anything do anything else. .. BTW
She's Alive so far so good one coolant leak lower line just below the manifold. Letting in cool down and ill get back to it...
I do have have a 2 car garage
..lol one side is full of the new deck furniture. . Aka my side... the other belongs to my PITA... So I'm stuck outside, don't mind the temperature it's the rain ....
mrjay62
Post by mrjay62 »
Hi guys.
So far she's running sounds good, had one little coolant leak! That's fixed ... Everything else seems fine I let her run for over an hour..
No trouble lights no over heatng and so far Nothing is leaking. Tomorrow I'll take for a test drive.... too late and dark now.....
I did mess up and added the wrong antifreeze to top it off..... Didnt realize until I went back outside to shut off the car.... oh well...
I Been using ZEREX G-05 50/50.... unless someone tells me thats wrong...
Thanks guys
