Wire identification help?
albertavolvo850
- Year and Model: 1996 Volvo 850 GLE
- wizechatmgr
- Has thanked: 45 times
- Been thanked: 128 times
Looks like the turbo control valve to me... But I thought you folks had the mechanical/vac. operated one...
- Has thanked: 2205 times
Did you get it figured out? Can't be a turbo valve as car is a non-turbo.
Are you in the Calgary area? If so I can try to help out.
- Year and Model: Many Volvos
- Been thanked: 76 times
Post back the wire colors, look for a colored stripe when you identify them since many of the wires are a color and then have a different color stripe.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Looks like purge valve connector to me.
GLE should be 10v car....so might be for IAT sensor at air intake hose.
If it isn't for purge valve post a picture of engine bay and air filter housing towards the engine.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
crlande
- Year and Model: 240DL;850;S70
- Been thanked: 36 times
Snake that connector under and behind the curved accordion throttle body hose( in your pictures) and you will a see the connection on a small device attached to the lower half of the air filter box.
- Has thanked: 311 times
- Been thanked: 817 times
I think not; sounds like you are referring to the boost control solenoid (BCS, TCV), which this car does not have.crlande wrote: 29 Oct 2018, 14:09 Snake that connector under and behind the curved accordion throttle body hose( in your pictures) and you will a see the connection on a small device attached to the lower half of the air filter box.
crlande
My '94 850 is NA and that is where it goes. It looks like a electric motor.There are two tiny white plastic tubes attached to other side of the device. You can even see one of the white hoses near the throttle cable in the first picture!
My bad, great suggestion!crlande wrote: 29 Oct 2018, 19:15 My '94 850 is NA and that is where it goes. It looks like a electric motor.There are two tiny white plastic tubes attached to other side of the device. You can even see one of the white hoses near the throttle cable in the first picture!
- Been thanked: 4069 times
I think it is an IAT sensor on the 10 valve non turbo 1994 in that location.
You could confirm by comparing wire colours to the wiring diagram
- 12 Replies
- 6648 Views
Last post by mrbrian200
- 12 Replies
- 2903 Views
Last post by MarcM
- 578 Views
Last post by genhawk21
- 1052 Views
Last post by misha
- 680 Views
