Tire rub on full-lock - spacers?
Arbelac
Year and Model:
Post by Arbelac »
So, I just picked up a nice 2001 V70 T5...with a manual :)
Car runs great, been maintained well, and has every option in the book, including the 17" wheels.
There are 235/45/17 tires on there right now, and according to the label those are the right size... but they rub on full-lock turns on the front.
Would installing some wheel spacers fix the rub? Any downsides or things to watch for when putting spacers in?
-1998 V70 Cross Country Wagon, B5254T, AWD, 231000KM
- 2001 V70 T5M, FWD, 205000KM, QBM Strut Brace Conversion, QBM Poly Lower Transmission Mount, HD Endlinks
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
My 16's rub on my S70 on full lock. You can ask JRL but I believe they sell some extensions for the steering stops that will keep you from rubbing but it will decrease your turn radius. Are you sure the correct wheels are on the car? Which ones? If it is a bad rub I would be concerned that non-Volvo wheels are on it and find out about spacers. Otherwise, keep your limitations in mind when you make full turns.
Arbelac
Year and Model:
Post by Arbelac »
Yeah, they are the Volvo rims. Did some additional searching and it looks like it might be due to the higher shoulder on the actual tires.
Wonder if just pushing them out 5mm would do it.
I suppose the other option would be to go with a narrower tire?
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
The P2 chassis was really not designed for 235/45s and depending on the tire they can and usually WILL rub.
You have a couple of options, you can get R steering stops which will make the turning circle akin to a battleship (43 ft)! or you can try 5mm spacers.
You didn't mention WHICH Volvo wheel and what brand of tire you have on?
It makes a difference with the different offsets and the actual tread block (width) of each brand of tire, some are wider than others.
Some tires are over 1/2" wider than other brands and that is enough to rub.
Why do you think Volvo uses (crappy) Pirellis? They have the narrowest tread block width of all the 235s out there
Arbelac
Year and Model:
Post by Arbelac »
JRL: How do I tell which rim it is? All I can tell is that it's the Volvo factory 17" rim that came with the car in 2001. They have "paired" spokes and have 7 spoke sets.
The tires are Hankook W400 snows.
MadeInJapan
This them?
Arbelac
Year and Model:
Post by Arbelac »
Yeah, that looks like them. Ooo, good reference...
MadeInJapan
Really, as JRL said, more than the wheel, the tire size and brand (type) is going to be more telling in your case.
dkretzer
Year and Model:
Post by dkretzer »
As JRL stated there appear to be different stops for wider rims. My only experience with this is my own '02 T5 w/ original 17s which as described, couldn't turn around in New York Harbor without the aid of a pilot boat. It turns like my friend's R. So, if your car was not factory equipped with these rims and tires you may want to seek out those stops.
Boxcar Man
Current: '99 V70 XC, '02 S60 T5, '74 MGBGT
Previous: 544, 122, 140 (3), 240 (3), 740
JRL
Post by JRL »
dkretzer wrote:As JRL stated there appear to be different stops for wider rims. My only experience with this is my own '02 T5 w/ original 17s which as described, couldn't turn around in New York Harbor without the aid of a pilot boat. It turns like my friend's R. So, if your car was not factory equipped with these rims and tires you may want to seek out those stops.
Try the spacers first (5mm)
I have them on my 06R, 18" wheels AND lowered, NO RUBBING!
