Thermostat Replacement Advice
callahanoffroad
Year and Model: 1995 850
Has thanked: 16 times
Been thanked: 52 times
Post by callahanoffroad »
Okay friends I need to change the thermostat on my 850 non turbo as the car isn't really blowing too much hot air except when I'm sitting still or when the engine is revving. So I'm thinking the thermostat is stuck open.
Well it's only two bolts right? No prob. Super easy. Except not. I cannot get the bolts to turn and I'm afraid I'm going to strip the bolts out. Any advice? I do have a massive impact wrench that I'm tempted to use.
WhatAmIDoing
Year and Model: 1998 S/V70 T5M
Has thanked: 104 times
Been thanked: 105 times
Post by WhatAmIDoing »
I've heard of using a dremel with a cutting wheel to cut slits into the bolt heads for removal with a large flat head screw driver.
I do not think these are common bolts to snap, usually just strip the heads, so I would try the impact. But first, soak everything in your favorite penetrating oil. Also, you are 100% going to want new, quality steel bolts.
'98 S70 T5M - 323,000mi - awaiting heart transplant :shock:
'99 S70 "AWD" - 220,000+mi - gone :cry:
Knows enough to be dangerous :wink:
Been thanked: 466 times
Post by cn90 »
Spray the bolts with PB Blaster etc.
Let it sit for a day then come back tomorrow.
callahanoffroad
WhatAmIDoing wrote: 17 Nov 2018, 16:05 I've heard of using a dremel with a cutting wheel to cut slits into the bolt heads for removal with a large flat head screw driver.
Any idea what size bolts they are?
Has thanked: 1836 times
Been thanked: 1709 times
+ 1 on what the guys have said. I also have an elongated 3/8" Torx socket which allows the shaft to sit square against the side of the head. When I soak it with penetrating oil I use the Torx socket and give it a few taps with a hammer to try to shock the aluminum and steel threads to give a gap for the penetrating oil to work down.
Let is sit for 24hrs and tap again before trying to remove. I have a long 3/8" breaker bar and with as much downward pressure as possible, give it sharp tugs to try to break it loose rather than a steady pressure. To date have not stripped a thread or break a thermostat housing. Problem as usual is modern manufacturers using dis-similar metals which react and 'weld' to each others.
Good luck!
xHeart
Year and Model: 2.0/3.2
Has thanked: 113 times
Been thanked: 115 times
Post by xHeart »
T40 long.
For a clean job the fuel line can be undone.
The torx head will likely strip. You will need two new screws.
callahanoffroad
Good news fcp carries new ones ready to go.
wizechatmgr
Has thanked: 45 times
Been thanked: 126 times
Post by wizechatmgr »
Worst case scenario - I believe the whole housing can be removed from the engine. Obviously this too isn't fun...
callahanoffroad
wizechatmgr wrote: 17 Nov 2018, 18:41 Worst case scenario - I believe the whole housing can be removed from the engine. Obviously this too isn't fun...
That's the, I'm taking my ball and going home scenario.
wizechatmgr
callahanoffroad wrote: 17 Nov 2018, 18:44
All else fails, cover half of the front of the radiator with cardboard until you can get it off - any heat that is more than you have will be heat you appreciate.
I believe I shocked my bolts with a couple pound sledge on the end of a 3/8" extension before I removed them.
