What’s winter fluid in JAX , June? Protected to 55F?June wrote: 21 Nov 2018, 14:26Just let the system continue to spray until out, then refill with winter fluid. Then run again until winter fluid sprays to flush lines. just did it a few days ago in my S80. JuneBEJinFbk wrote: 21 Nov 2018, 14:13 Gonna be tough...
Washer fluid tank is
buried way down there.
Maybe a vac syringe
with a really long hose?
New England Winter for a Desert Volvo? Topic is solved
BEJinFbk wrote: 21 Nov 2018, 19:48 FYI - Here's what you're woking with:
Hope that helps!
viper69
- Year and Model: 850GLT 1995
- Has thanked: 77 times
- Been thanked: 2 times
Thanks. I should have mentioned I’ve seen the bizarre placement of the tank as the original one cracked a few yrs ago.BEJinFbk wrote: 21 Nov 2018, 19:48 FYI - Here's what you're woking with:
Hope that helps!
Volvo 850 GLT 1995
5 Speed Manual transmission
122,500 miles and barely broken in
'82 Volvo DL Wagon, 4 speed manual
'77 Saab 99 EMS, 4 speed manual
viper69
Not sure what you meant by this.... concentrate of what?Rattnalle wrote: 21 Nov 2018, 14:35 Add concentrate to get it to a decent freezing point quicker without having to empty it.
Volvo 850 GLT 1995
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
Wiper fluid.
At least over here they usually sell in -18 C ready to use or concentrate that does -30 C in a 1:1 water mix. Adding just a liter or so of that is enough to get the whole tank down to -10 C or so at least. That usually does it for the first few weeks of freezing nights and such.
viper69
Didn’t know that, I’ll take a look!Rattnalle wrote: 22 Nov 2018, 10:27Wiper fluid.
Volvo 850 GLT 1995
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
Or this
- Untitled.jpg (19.84 KiB) Viewed 1900 times
viper69
Not sure if I can get that in USA
Volvo 850 GLT 1995
- oragex
The 'coldest' one seems to be a Rain-x on Walmart USA. There may some marketing opportunities for Alaska perhaps
https://www.walmart.com/ip/Rain-x-30f-D ... /187143633
viper69
oragex wrote: 22 Nov 2018, 19:28 The 'coldest' one seems to be a Rain-x on Walmart USA. There may some marketing opportunities for Alaska perhaps
Agreed, I just found the purple one from them a minute ago. They make 2 orange variants rated about -25, one with a de-ICER, and One without I think.
But up in Canada RainX did sell a -40 version at one point via WalMart.
Volvo 850 GLT 1995
