Gunk in the oil dipstick tube
Has thanked: 312 times
Been thanked: 818 times
There's no PCV valve in your car. What did your mechanic say had varnish? Or even better maybe he showed it to you.
Dave in Maine
Year and Model: 2009 S60 2.5T
Been thanked: 3 times
Post by Dave in Maine »
The one in this video.
or this video
The part all the way at the end had about 50% closed with varnish that had been oil. I saw it.
1996 850 Turbo Gold Edition, 7 years' reliable service and >220k mi, sadly now gone
2009 S60 2.5T, sent away after taking me down Via Dolorosa. Happy to be rid of it.
Has thanked: 1611 times
Been thanked: 4075 times
It’s often ( mistakenly) called the PTC valve but it is just an orfice with a heater. It’s a maintenance item to be cleaned every 30-60k miles
What he said. the PTC is a heating element, it has no moving parts. If that was clogged up then it's good it was cleaned.
The PTC is indeed part of the PCV system and one of several places that need to be inspected and cleaned when servicing. The heart of the system is the oil trap and it's hoses with their passages into the block, hopefully that was all cleaned out too. If the PTC was clogged, good bet the main PCV areas were clogged too - these are more prone to clogging and arguably more important to service.
