Do Hood Springs Wear Out? Topic is solved
MrAl
Year and Model: v70, 1998
Has thanked: 83 times
Been thanked: 73 times
Post by MrAl »
Hello,
Do the springs that push the hood up wear out over time?
The other day i could not get the hood open, and i think it was because the springs seemed too weak.
Any ideas?
rspi
Has thanked: 34 times
Been thanked: 72 times
Post by rspi »
jimmy57
Been thanked: 320 times
Post by jimmy57 »
The hinges get rusty, the hood cracks around the area where the hood latch bar mounts on either side, and the latches need adjustment and/or lubricating are all causes for it not pop up. If any of those is wrong and you add something that forces hood upwards then you'll work around the real issue. At least in my experience.
Matty Moo
Year and Model: 850, 1996
Been thanked: 30 times
Post by Matty Moo »
I've had my hood opened and closed way over 2000 times, I don't think they wear out.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
WhatAmIDoing
Year and Model: 1998 S/V70 T5M
Has thanked: 104 times
Been thanked: 105 times
Post by WhatAmIDoing »
You can open the hood without springs, it will just be very heavy and not stay up (unless Volvo's spring system magically works differently). What usually keeps hoods from going up is rusty hinges, broken latch, or misalignment. Did you hit anything with the front end?
'98 S70 T5M - 323,000mi - awaiting heart transplant :shock:
'99 S70 "AWD" - 220,000+mi - gone :cry:
Knows enough to be dangerous :wink:
Year and Model: Many Volvos
Been thanked: 75 times
Post by Ozark Lee »
Replacing the springs is not for the faint at heart. The preload on them is pretty unreal.
I can't really remember what happened to my daughter's S70 but I went to a pick-n-pull to get a pair of hinges and springs and after I got the old ones out I was really sure I didn't want to replace them. I think I just bent stuff back until the old ones would operate again.
MrAl
Post by MrAl »
Hello,
Thanks for the replies everyone.
I guess i am going to have to apply some elbow grease to this problem, as well as using some more lube on the mechanisms.
Has thanked: 1502 times
Been thanked: 3813 times
I am more worried that some people count their hood cycles. Is a cycle an open and shut or just an open? What if you open it twice without closing?
hausmeister
Year and Model: 1995 850T5-R
Has thanked: 250 times
Been thanked: 77 times
Post by hausmeister »
The hood locking mechanism on my 850 was worn down, but the springs are still ok. I think they last a human lifetime ;)
850 T5-R '95 auto Image
MrAl
Post by MrAl »
hausmeister wrote: 07 Dec 2018, 05:01 The hood locking mechanism on my 850 was worn down, but the springs are still ok. I think they last a human lifetime ;)
Hi,
That's good to know. I wonder if there is a test for this though.
