Hello,
Do the springs that push the hood up wear out over time?
The other day i could not get the hood open, and i think it was because the springs seemed too weak.
Any ideas?
Do Hood Springs Wear Out? Topic is solved
- MrAl
- Year and Model: v70, 1998
- Has thanked: 83 times
- Been thanked: 73 times
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
jimmy57
- Been thanked: 320 times
The hinges get rusty, the hood cracks around the area where the hood latch bar mounts on either side, and the latches need adjustment and/or lubricating are all causes for it not pop up. If any of those is wrong and you add something that forces hood upwards then you'll work around the real issue. At least in my experience.
Matty Moo
- Year and Model: 850, 1996
- Has thanked: 1 time
- Been thanked: 30 times
I've had my hood opened and closed way over 2000 times, I don't think they wear out.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
- WhatAmIDoing
- Has thanked: 104 times
- Been thanked: 105 times
You can open the hood without springs, it will just be very heavy and not stay up (unless Volvo's spring system magically works differently). What usually keeps hoods from going up is rusty hinges, broken latch, or misalignment. Did you hit anything with the front end?
Knows enough to be dangerous
- Year and Model: Many Volvos
- Been thanked: 75 times
Replacing the springs is not for the faint at heart. The preload on them is pretty unreal.
I can't really remember what happened to my daughter's S70 but I went to a pick-n-pull to get a pair of hinges and springs and after I got the old ones out I was really sure I didn't want to replace them. I think I just bent stuff back until the old ones would operate again.
- MrAl
Hello,
Thanks for the replies everyone.
I guess i am going to have to apply some elbow grease to this problem, as well as using some more lube on the mechanisms.
- Has thanked: 1497 times
- Been thanked: 3810 times
I am more worried that some people count their hood cycles. Is a cycle an open and shut or just an open? What if you open it twice without closing?
hausmeister
- Year and Model: 1995 850T5-R
- Has thanked: 250 times
- Been thanked: 77 times
The hood locking mechanism on my 850 was worn down, but the springs are still ok. I think they last a human lifetime
850 T5-R '95 auto
- MrAl
Hi,hausmeister wrote: ↑07 Dec 2018, 05:01 The hood locking mechanism on my 850 was worn down, but the springs are still ok. I think they last a human lifetime![]()
That's good to know. I wonder if there is a test for this though.
- 11 Replies
- 2207 Views
Last post by icrashcars
- 21 Replies
- 2548 Views
Last post by WhatAmIDoing
