Do Hood Springs Wear Out? Topic is solved
MrAl
Year and Model: v70, 1998
Has thanked: 83 times
Been thanked: 73 times
Re: Do Hood Springs Wear Out?
Post by MrAl »
abscate wrote: 06 Dec 2018, 18:35 I am more worried that some people count their hood cycles. Is a cycle an open and shut or just an open? What if you open it twice without closing?
Hi,
That's still an 'open' question in science :-)
My guess is that you have to be in one of those alternate universes where hoods open, pop out of existence, then a new hood pops into existence in the closed position.
This conjecture is based on the 'Many Worlds' interpretation of quantum physics, as well as 'virtual' particles.
Sounds like a joke right? You might be surprised if you look all that up and you never read about that before...or bored if you did. Might be improbable, but not impossible.
Also following that line of thought, in another universe it could be happening over and over again right now as you read this. In our world, the probability is so low that it could take trillions and trillions of years to happen even once, and that means of course that we will not be around to see it unless gene therapy makes a few more advances and science advances to the point of being about to create stars and planets or we actually advance to the point where we can inhabit other places in the universe and nothing catastropic goes wrong in our known universe or we can find a way to inhabit other universes.
Sounds crazy right? Do some reading :-)
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2654 times
Been thanked: 1247 times
Post by matthew1 »
Can hood springs be worn out and not worn at at the same time? Schrodinger's hood.
Also -> Amazon link
wizechatmgr
Has thanked: 45 times
Been thanked: 126 times
Post by wizechatmgr »
matthew1 wrote: 09 Dec 2018, 12:35 Can hood springs be worn out and not worn at at the same time? Schrodinger's hood.
Sounds an awful lot like a failed marriage - a subject I have some expertise in. =)
MrAl
Post by MrAl »
Hi,
Ha ha, that's a good one.
The answer is of course that we dont know for sure until we open the hood :-)
One time i opened the garbage can outside and a squirrel jumped out and right on me, then jumped off.
That thing was DEFINITELY alive :-)
On a more serious note, maybe there is a measurement with say a spring scale. Test the upward pull.
Has thanked: 1505 times
Been thanked: 3817 times
You can put your hood up and measure 10 coil lengths. Then someone else can compare one from a car with a good hood!
Has thanked: 292 times
Been thanked: 765 times
Please, make it stop!
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 93 times
Been thanked: 146 times
Post by BEJinFbk »
erikv11 wrote: 12 Dec 2018, 15:21 Please, make it stop!
Ok...
“Do hood springs wear out?”
NO. Not in our lifetimes.
Ask anyone with ‘72 Impala.
MrAl
Post by MrAl »
abscate wrote: 12 Dec 2018, 11:20 You can put your hood up and measure 10 coil lengths. Then someone else can compare one from a car with a good hood!
Hi,
Well i looked but i dont see any springs, they must be under there somewhere. I just see the lever mechanism.
MrAl
Post by MrAl »
Hi,
Make what stop?
MrAl
Post by MrAl »
BEJinFbk wrote: 12 Dec 2018, 18:33
Ok...
Hi,
I am assuming that Volvo is unique. So many weird things with this car i have to assume that anyway.
