2000 volvo s80 2.9
Ttwerie
Year and Model: 2000 volvo s80 2.9L
Re: 2000 volvo s80 2.9
Post by Ttwerie »
As far as heat goes this was a problem before timing kit intalled. Its a heater core issue I am pretty sure so not priority ar this time. State inspection is 😩🤷🏻‍♂️
I will have to go back and retrieve code again. Its definately said heater control bank 2 and I believe P0500 code. I will update with EXACTLY what reader say’s when I get a chance to go back in. My bad for not writing down! 19yrs with this car you think I would know better🙄
Thank you
SuperHerman
Been thanked: 207 times
Post by SuperHerman »
A P0500 comes up as a speed sensor - which would align with your tranny light.
As for the heater core, if it is not leaking you can try back flushing it. First make sure your thermostat is working correctly. Some people use CLR as a wash to clean out the crud. You can pull the two heater core hoses at the firewall and hook up some hoses and a bucket. Do a search for heater core back flush and you will find some videos - the Volvo design is pretty easy to rig up. Once you are done just use some water to further flush, maybe followed by some distilled water. Then air - you could even blow into the hose if need be.
The only concern is clearing the crud may cause a leak, but if the heater core is that bad it will leak soon enough.
Ttwerie
Post by Ttwerie »
I have the exact code and details from OBD
Its P0050 HO2S Heater Control Circuit
(Bank 2, Sensor 1)
Please follow up with location of this o2 sensor
Thanks once again!
Ttwerie
Post by Ttwerie »
(Bank 2, Sensor 1)
Thanks once again!
