When do things start to go? Topic is solved
Messerschmitt101
Year and Model: 1996 850
Has thanked: 12 times
Post by Messerschmitt101 »
Hey everyone,
Up until recently, I have been extremely happy with my '96 850. Though the odometer is broken, estimates of miles I have seen point mileage to be north of 300k. Sadly, the tranny is starting to seem like it's about to drop (It's with AAMCO now so they can check).
Anyway, I am looking for a new-to-me volvo, and in my area I am seeing a lot of S60s and V70s (mostly AWD/XC). I just wanted to pose the question of where things start to go wrong on these cars, as well as what I would have to do. I'm sure the basics like spark plugs, filters, brakes, fluids, and tires are likely to be mentioned. If you all have any words of wisdom to drop on me, please do so. I should also mention, I am mainly looking at automatics, not manual since I haven't yet learned how to drive stick (Sad I know).
I will keep this thread updated on the status of the 850 (fingers crossed!), and whether I go with an S60/V70 or not.
Also, please tell me of your experiences with these vehicles, both good and bad.
Take care everyone.
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
Messerschmitt101 wrote: 01 Feb 2019, 09:46 I just wanted to pose the question of where things start to go wrong on these cars, as well as what I would have to do.
Thing start to go wrong when maintenance and repairs are deferred.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2654 times
Been thanked: 1247 times
Post by matthew1 »
About 40 for me.
:lol: :wink: :roll:
Also -> Amazon link
mrbrian200
Has thanked: 7 times
Been thanked: 84 times
Post by mrbrian200 »
40..
Somewhere around there I had to switch to premium fuel and step up the maintenance routine. So long as I stick to it I don't notice any difference from when I was 25...so long as I don't look in the mirror.
matthew1
Site Admin
Post by matthew1 »
:lol:
Messerschmitt101, I take it you're talking about 2000s Volvos, not recent? If so, you need to be able to turn your own wrenches or you'll be writing big checks.
Tell us about how your approach/tolerance to/skill level at car maintenance.
Short answer: any 2000s Volvo will be past the point where they start to go.
Also -> Amazon link
Messerschmitt101
matthew1 wrote: 01 Feb 2019, 11:18 :lol:
Well, like I said, I have the 850 and have done control arms, engine mount bearing (the rubber one on top), radiator and radiator hoses, and was planning to do brakes, and shocks/struts before taking it in.
Skill level wise, I would say basic, but learning, and not afraid to do my own work. The only thing I paid a mechaninc to do was the timing belt/water pump (I bought the part, they did the labor) since I didn't want to put in the effort of taking the whole engine apart and re-timing it.
And yes, most of the P2s I am looking at are between 2000-2005 (2nd gen).
Also, thaks for the laugh earlier (seem slike I've got a little while till things go wrong :lol: ).
Been thanked: 471 times
Post by cn90 »
The car is similar to a human being. Every part/organ has a life expectancy.
Search forum for lifespan of:
- Alternator
- Tstat
- PCV system
- Suspension system
- Timing Belt
etc. etc.
Best is buy a car with 80K, drive it to 150K and sell it. Best bang for the bucks...
chrism
Year and Model: S80 / 2005
Been thanked: 78 times
Post by chrism »
You'll probably want to go with a 2003 or newer in order to avoid the quirky transmissions and to get a Bosch throttle body vs the Magnetti Marelli. A verifiable maintenance record is quite valuable. Don't buy anything with a check engine light on or if it "just needs a tune up" - if it was a simple fix the seller would have already fixed it. No cars from Houston or any other hurricane zone (flood damage).
Messerschmitt101
Okay, so turns out I jumped the gun on this whole thing.
My 850 is perfectly fine, just needs CV axles to be replaced (so that it stops leaking transmission fluid). I will be in the 850 forum asking about this job, but I am sure I can do it myself (and save round-about $450-$500).
Thank you all for helping me out on this, even though it didn't go anywhere. It'll be a good baseline for when I actually do start looking for a newer car.
Rattnalle
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
cn90 wrote: 01 Feb 2019, 13:59 The car is similar to a human being. Every part/organ has a life expectancy.
- Alternator
- Tstat
- PCV system
- Suspension system
- Timing Belt
etc. etc.
You keep it til things start to go. Generally it'll get cheaper and cheaper per year and mile until something big goes, then you start over. For a whole lot of these cars that won't be until you get (far) north of 200k. With proper but not excessive routine maintenance.
Just avoid the AWD. Chances are it isn't working anyway. Get a -04 or later. The NA has the new throttle and the turbo is the newer nicer engine tune.
