Volvo 850 power loss under hard acceleration Topic is solved
Jaumme
Year and Model: Volvo 850 T5 1993
Re: Volvo 850 power loss under hard acceleration
Post by Jaumme »
Y squeezed the return Lane And the pressure kept the same, i think the pressure rise when i start the engine is caused because the alternator is giving a little more voltaje than batery does?
Sommerfeldt
Year and Model: 2018 S90 T8
Has thanked: 55 times
Been thanked: 42 times
Post by Sommerfeldt »
Jaumme wrote: 29 Jan 2019, 13:29 Y squeezed the return Lane And the pressure kept the same, i think the pressure rise when i start the engine is caused because the alternator is giving a little more voltaje than batery does?
That kind of brings us around to the pump again. Pressure should climb quickly with return line closed. If it doesn't that means replace pump.
- S
[Sold] '97 S70 T5
Has thanked: 1505 times
Been thanked: 3818 times
Pruned some posts that definitely were running low on lubricant.
Thanks for self moderating, people.
Jaumme
Post by Jaumme »
Just replaced the fuel pump today And no more Power loss.
Thank you all for the help
misha
Has thanked: 152 times
Been thanked: 402 times
Post by misha »
I guess that pdf narrowed it down. :wink:
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Sommerfeldt
Jaumme wrote: 01 Feb 2019, 14:20 Just replaced the fuel pump today And no more Power loss.
Nice! Clemens got it spot on from the get-go. :mrgreen:
- S
[Sold] '97 S70 T5
Jaumme
Post by Jaumme »
Another question, is that boost normal or low? If its los what can cause It?
Cookeh
Year and Model: 1996 Volvo 850 T5
Has thanked: 77 times
Been thanked: 59 times
Post by Cookeh »
That's about as far as mine goes on the boost gauge, so Id be interested in knowing if its normal too!
Clemens
Has thanked: 473 times
Been thanked: 219 times
Post by Clemens »
Sommerfeldt wrote: 03 Feb 2019, 22:18
- S
Great! What do I win ;-)
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
Clemens
Post by Clemens »
Cookeh wrote: 07 Feb 2019, 08:39 That's about as far as mine goes on the boost gauge, so Id be interested in knowing if its normal too!
That is quite normal for a T5, maybe a bit low. The R models go a bit further. And my T5M goes a bit further as well, but then drops back immediately because it has boost spikes.
you can always shorten the wastegate rod a bit (by like 1-2 turns the max.), but be careful because you can cause harm. Use a vac tool to set the base value of (I think) 1.8 psi for the M4.3 T5s and then shorten by about a turn. This wakes up the brick at low rps/speeds.
Please do some reseearch, I am writing based on my (confused) memories.
Summer: 1996 855 R
Donor: 1995 854 10V
