S60 smokes badly when idling
notny41
Year and Model:
Post by notny41 »
Gotcha! I was just going to ask how the turbo could put oil into the cylinders which didn't seem likely or possible, but now this makes sense that it isn't putting oil into the cylinders it is possibly putting oil into the exhaust.
Are those seals very hard to replace? I bought a set off ebay for it. They were cheap (OEM volvo parts) but the labor to put them on is going to be the expensive part. Unless it is possible for a fairly mechanically inclined bloke like myself to be able to do it.
Anyone done this before on their S60 AWD?
Thanks!
sseir39
Year and Model:
Post by sseir39 »
The turbo has to be removed from the exhaust manifold. I have repalced turbos but never overhauled them. There are rebuilders who do a good job. I have picked up used ones too. Count on spending $250 to $350 for a rebuild and used---maybe less. Just know your used supplier.
notny41
Year and Model:
Post by notny41 »
Can a guy just get by with replacing the seals or is that the same as rebuilding it?
How big of a job is it to remove the turbo and put a different one on? Can you do it without removing the notorious "Angle gear" whatever that is?(keep in mind this is an AWD)
sseir39
Year and Model:
Post by sseir39 »
It is not a quick job, but providing it is just a FWD, you do have to take off coolant and oil lines, the air inlet and outlet pipes, coupling to the exhaust , and oil return line. Believe heat shields come off and 4 nuts holding the turbo to the exhaust manifold. Replacing seals is essentially a rebuild. Might want to look at a manual on how-to as there are perhaps things I have forgotten.
notny41
Year and Model:
Post by notny41 »
Hmmm. So it is an AWD and I suppose that adds complexity to the whole thing. I wonder if "seals" is the right term for what I have.
MadeInJapan
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Gasket and o-ring.
notny41
Year and Model:
Post by notny41 »
I'm guessing that means neither are a "seal"...?
MadeInJapan
Well, they both are if you want to know the truth.
sseir39
Year and Model:
Post by sseir39 »
Agree--the actual turbo seal is inside the turbo, i.e. you need to remove the entire turbo and then you can use your oil return gasket and seal.
MadeInJapan
True, the turbo seal is something that is tackled when you rebuild the turbo but the pictures of the items above are installed without removing the turbo. Both are for the oil return line- one (0-ring) is the connection to the sump, the other (gasket) is on the turbo side.
