Hi
I found this under my car. What is it and how do I put it back?
what is this part?
YK1Spartan
- Year and Model: 2006 XC 90
- ggleavitt
- Year and Model: 06,08 XC90 V8
- Has thanked: 24 times
- Been thanked: 127 times
Nothing like a good challenge to start the day. Damper for a diesel, #5 on the diagram, can see where its supposed to be mounted. Little odd that you found it on the ground, find a large bolt down there as well?
2006 V8 Ocean Race #740/800 200k, 2008 V8 Sport 183k
YK1Spartan
did not find on the ground, found it in that plastic cover no 43. did not find a bolt. how important is it?
- mrbrian200
- Has thanked: 7 times
- Been thanked: 84 times
I'm curious as to what's inside that little thing.
Umm, one second looking at the diagram: if you found that on the ground this would mean the bolt that attaches your upper engine mount fell out/engine mount disconnected. You want to rectify this situation immediately with a new bolt/nut.
If the engine mount is intact (bolt is not missing) this would indicate a previous service/mechanic left this under the hood/missed putting it back where it belongs after having this apart.
YK1Spartan
- Has thanked: 1511 times
- Been thanked: 3827 times
Those guys charging $150 an hour for their work botched this one.
It’s even better that you found it as it’s a NLA part!
I love curious people, Mr Brian. Love to open this up and see what’s inside? Swedish oak chips maybe?
- RickHaleParker
- Been thanked: 958 times
It is a Damper so I'll bet on different masses inside depending on application. A green mass for some applications. A yellow mass for other applications.
Does this thing have some sharp resonance IT absorbs from the engine top mount?
We found a similar thing on wizechatmgrs XC70, a metal box under the car bolted to the frame and mounts filled with Swedish squirrel dung. Yellow type.
