P80 PS pump orings 969092 dimensions request?
Has thanked: 1507 times
Been thanked: 3823 times
Anyone measured the dimensions so they can be bought locally without having to take the pump apart?
$2 from Volvo parts Lisle
0.29 for PPS from FCP with lifetime warranty to be round and green
:mrgreen:
High pressure pump line uses four of these, two at each end
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
Awesome, thank you rick
measure the id to 0.307 a 302 pin is loose and a 5/16 pin is just a tad over. The width is 0.072 so the size they gave me is a -011. (5/16 ID by 7/16 OD 1/16 Wide) That size is included in the Harbor Freight HNBR set #67644 as reference if someone else gets stranded on a weekend. Be careful with using Home Depot o-rings. EPDM is very common for water etc and that will not do well with oil or gasoline.
wizechatmgr
Has thanked: 45 times
Been thanked: 126 times
Post by wizechatmgr »
I may have a spare at home in that pump I picked up. Want me to grab it? It will at least get you running for now...
Can you run it over to OH for me too?
wizechatmgr
As you're aware, forgot that sucker today. Would having it Tuesday be okay? I can bring the entire pump...
