I need a replacement radiator for a V70. I am considering going genuine Volvo despite the considerable price premium.
I had also thought about harvesting a used one from Harry's for about half the price of new aftermarket. I've never changed a radiator, so I was thinking pulling a used one would give me installation insights.
Plan would be to replace all hose clips & clamps and replace any hoses with new as needed.
Thoughts?
Used Volvo Radiator from Pick & Pull
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 111 times
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- Antoine240bk
- Year and Model: XC70 2.5T-2006 - 4C
- Has thanked: 12 times
- Been thanked: 30 times
Hi,
You could go for a used genuine Volvo radiator if it is in great condition, and no deposit at the bottom, this will avoid doing the job twice!
I have gone with a new rad Nissen brand on my V70, quite well made for half the price and silicone hoses too. There is a few tricks you will have to do, as support the AC Radiator and the Rad to make it easier. I did drain the coolant first and then blow a good breath through the coolant tank, this as drained more coolant from the heater matrix circuit.
While at it check and change your thermostat coolant seal
Volvo XC70 2.5 T AWD P2 B5254T2 - 12/2005 Four-C Previous : Volvo V70 P1 2.4l 20s 170ch B5244S 03/2000 - Volvo 245 GL Break 1979 B21 -LPG - Volvo 240 GL Break 04/1992 B230F (Daily for 14 years)
- SuperHerman
- Been thanked: 207 times
There are write ups on the process on this forum, one of them pretty recent.
The only item I will add is do not twist the radiator when removing and installing. The number one source of leaks is at the edges, where twisting shows its impact. Many have installed new radiators and have them fail w/n a few years because they twisted them during the process. So straight up and straight down - remove anything in the way to avoid twisting.
A used unit with a good warranty on an older car is not a bad idea. After market radiators, the ones I have used, have not been a problem. Nissen is a solid brand.
- Has thanked: 1500 times
- Been thanked: 3812 times
Start hitting the two bolts holding the radiator ears with PB elixir two weeks before attempting to loosen them.
I got 14 years out of the Volvo and 4 out of the Nissens. I think the 4 was my bad install, not the radiator quality
Cost savings of a junkyard is lost in the pulling labor if you give yourself a fair wage for that. I use $25/ hour
- E Showell
You think it will take me 8 hrs. to pull?
'95 855 auto (sold)
'95 855 auto (sold)
crlande
- Year and Model: 240DL;850;S70
- Been thanked: 36 times
Harry's Allentown just crushed their only 98. Hazelton has several. Considering the drive time there and back, the time to pull, the snow we are getting now, no good way to verify if good, $25 / hr sounds good as long as you don't have to pay NY taxes!
- E Showell
Yeah, I sold the '98. So, I don't need a radiator for that.
'95 855 auto (sold)
'95 855 auto (sold)
FCP with lifetime warranty. $125 Nissens
Harry's. $45
Difference is $80 for labor for brand new part over a used part
For me, no brainer for new.
- E Showell
Genuine Volvo $300, Harry's $45. Big Delta.
'95 855 auto (sold)
'95 855 auto (sold)
I would go new Nissens on this one on my cars, Volvo on yours which are often a nasty tow away from home.
Rethinking. Nissens for you , too,
