Swerve/pull when braking
XC90Inhwmv
Year and Model: 2005 XC90
Post by XC90Inhwmv »
I have a 2005 XC90 that swerves or pulls to the right when braking. It feels like something is loose and the vehicle swerves to the right and when you release the brake it goes back straight. Any ideas?
Masscomguru
Year and Model: 2010 XC90 V8
Been thanked: 16 times
Post by Masscomguru »
You're lower control arm bushings are shot.
Year and Model: Lots
Been thanked: 128 times
Post by precopster »
We had the same thing on our 2006 XC90. Visually the rubber looked fine. Not a tear in sight....but they were mushy on the left side control arm vertical bush.
I pressed in a new vertical bushing and all is now fine.
XC90Inhwmv
Thanks for the replies. I looked at the lower control arm bushings and your right, they don’t look that bad other than a little tearing of the rubber. I’m going to replace them and I’ll let you know how it turns out.
XC90Inhwmv
Well, both front lower control arms have been replaced and the problem is still happening. Not sure where to look next.
Masscomguru
What brand did you replace them with? there have been numerous accounts of cheap LCAs not performing correctly. For these I would highly recommend just having the bushings replaced with Volvo OE bushings or Myle HD versions (although, those will not last long if you do a lot of mileage).
tardcart
Year and Model: 96 850t. 93 940t
Has thanked: 3 times
Been thanked: 37 times
Post by tardcart »
your left front caliper could be stuck so only braking on right.
XC90Inhwmv
Well, it looks like the front control arms did fix the problem after all. I got bad feedback from the driver after the repair. I drove the vehicle after and the problem is not happening. Thank you to everyone who responded with help.
