P80 bypass ps pump, which belt, which routing
Has thanked: 1611 times
Been thanked: 4073 times
Isn’t the stocking trick in the Haynes manual?
Ta- dum, crash....
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
wizechatmgr wrote: 17 Mar 2019, 00:34 Pull my "red neck alternator" trick of putting a genny in the back seat with all windows open and a battery charger plugged in.
What are we thinking!? ... The battery charger is not need. Take the alternator off and use it to build the genny. Then connect the output of the Alternator to the battery. :wink:
Active
Past
tardcart
Year and Model: 96 850t. 93 940t
Has thanked: 3 times
Been thanked: 37 times
Post by tardcart »
you couldn't loop the pump back on the road unless you were desperate. You would need a tubing cutter or hack saw to ruin the
high pressure line and get it on the return line with a hose clamp and extra fluid you would have to bleed out of the transmission cooler line with only an old coffee cup to catch it, to put in the resivour. then you would probably fine the velocity back to the pump would froth the fluid out the cap.
I’m looking for a link to an adjustable emergency serpentine belt....
https://www.agrisales-inc.com/durodrive ... gLsm_D_BwE
$7 a foot?
tardcart
Post by tardcart »
I can see from the diagram a short belt won't work. It reminds me when I was in Cuba 20 years ago. A driver was taking me east from Havana and the belt broke. I said we can wait for the car to cool and almost coast into the town ahead and get a belt at the auto parts store. He said "what do you think this is paradise? there is no parts there." To him, paradise is where you can get parts for your car. I asked to see his trunk and found some clothes line and made a belt that lasted two hours till my destination in that Russian Pugeot copy.
to this day when someone thinks something is easy I say"what do you think this is, Paradise?"
RickHaleParker
Pants belt ... the type that is held in place with a tension latch. :?
A couple of them might limp one home.
Active
Past
The ingenuity of people in Eastern Europe is without bounds, even better than Cuba
wizechatmgr
Has thanked: 45 times
Been thanked: 129 times
Post by wizechatmgr »
RickHaleParker wrote: 17 Mar 2019, 10:57
You are so right. Rookie mistake =)
2023 Lexus RZ450e -66k
Update on this thread
It has been reported here that someone has driven an empty PS pump with just residual oil in it for 100 miles, one week with no ill effects.
magna224
Year and Model: 850 T5's
Been thanked: 4 times
Post by magna224 »
I've driven mine for 2 weeks of daily driving before with almost none in it because I didn't have money for a new res and fluid. Its pretty darn tough to turn though crawling through parking lots. Not something I would want to do again.
Volvo 855 T5 1995
Volvo 854 T5 1996
Toyota MR2 1987
