1996 850 2.3T blown #2 Rod at 208k
Jazzer
Year and Model: 1996 850 Turbo
Has thanked: 2 times
Post by Jazzer »
Hi guys,
it's been a long time since my last visit but I've gotten around to doing some more work on the 96 Platinum 850 turbo 2.3 wagon, 208k miles. Long story short, a friend had borrowed it for a few months and he called to say it had died on his way home and there was no oil on the dipstick. Ugh. Anyway, had it towed to my place; good news is, it wasn't seized (I was able to rotate the crankshaft), but it took me a while to find the source of the (sudden) leak: after draining the existing oil, which was about 2-3 quarts, I removed the filter and saw this hole:
I originally thought it may have been an oil cooler line that blew, since the oil had sprayed all over the front of the engine. This actually may be a cheaper fix than new cooler lines, parts-wise, but I don't know; do I just need to replace the pan? I'm guessing this isn't a mend-able hole; it looks like he may have hit a rock or pothole or something that pushed the oil filter into the pan?
Anyway, Thanks in advance for your advice!
Bob
mrbrian200
Has thanked: 7 times
Been thanked: 84 times
Post by mrbrian200 »
That looks more like a casting flaw to me: metal was too thin in that area and eventually just gave way.
GlennG2759
Year and Model: 2006 V70 NA
Has thanked: 112 times
Been thanked: 17 times
Post by GlennG2759 »
I agree, any visible damage to oil filter?
oragex
Year and Model: S60 2003
Has thanked: 102 times
Been thanked: 352 times
Post by oragex »
I thought it would have been caused by some random tool while removing the filter cup but it it happened all of a sudden while driving, that's strange, the engine runs fine ? A blown rod may do that. The first thing is to measure the oil pressure once fixed. I'd use some JB weld or replace the pan
Has thanked: 1502 times
Been thanked: 3817 times
oragex wrote: 18 Mar 2019, 11:39 I thought it would have been caused by some random tool while removing the filter cup but it it happened all of a sudden while driving, that's strange, the engine runs fine ? A blown rod may do that. The first thing is to measure the oil pressure once fixed. I'd use some JB weld or replace the pan
Tool damage, I agree.
Rattnalle
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
It doesn't look like there's any sign of outside interference, tool marks next to it or anything. It looks like it cleanly ground down from inside.
Wait a minute - isnt that an eyeball looking out? Maybe the poor guy who lubricates the back of the pistons wants a break from work??
Screen Shot 2019-03-18 at 2.40.56 PM.png (152.85 KiB) Viewed 1035 times
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
Jazzer wrote: 18 Mar 2019, 09:42 I'm guessing this isn't a mend-able hole; it looks like he may have hit a rock or pothole or something that pushed the oil filter into the pan?
J-B Weld with some screen as a framework.
Get the metal squeaky clean, rub it down with Acetone, let dry so it the J-B Weld will bond well.
WhatAmIDoing
Year and Model: 1998 S/V70 T5M
Has thanked: 104 times
Been thanked: 105 times
Post by WhatAmIDoing »
I'd go with JBweld to confirm the engine isn't toasted. If you still have oil pressure and don't hear expensive noises, then I'd pull a junkyard pan and replace it for piece of mind. Any damage to the filter or other parts of the underside?
'98 S70 T5M - 323,000mi - awaiting heart transplant :shock:
'99 S70 "AWD" - 220,000+mi - gone :cry:
Knows enough to be dangerous :wink:
tardcart
Year and Model: 96 850t. 93 940t
Has thanked: 3 times
Been thanked: 37 times
Post by tardcart »
Oragex is correct: blown rod. It may still run but now it will be a four cylinder car. This is why its bad to loan cars. It puts them and you in a bad spot. It may not be is fault at all. but I bet the oil was low and he didn't see the light.
