Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 112 times
Re: What did you do to your Volvo today? (now Sticky!!)
Post by Goupil »
I found why my parking break was weak :mrgreen:
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
Goupil wrote: 19 Mar 2019, 14:44 I found why my parking break was weak :mrgreen:
Yep... that'll do it!
wizechatmgr
Has thanked: 45 times
Been thanked: 126 times
Post by wizechatmgr »
Had both control arms and both inner and outer tie-rods replaced as well as an alignment.
Now instead of pulling to the right it pulls to the left. You can't make this stuff up...
Has thanked: 1505 times
Been thanked: 3818 times
Oh crap, wcm. At least you don’t have to JB weld your brake linings back on...
850 LPT
Year and Model: 96' 850
Has thanked: 331 times
Been thanked: 242 times
Post by 850 LPT »
wizechatmgr wrote: 19 Mar 2019, 21:57 Had both control arms and both inner and outer tie-rods replaced as well as an alignment.
I have the same thing happening to me before on more than one car.
If you don't have rotational tires cross swap the fronts and see if that solves it.
This helped me already a few times.
Dirk
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
Spare set of wheels if you want to try a swap, too.
bmdubya1198
It's amazing how tires will cause a pull, I had that after rotating my tires when I was riding on the stock Antlias. Definitely worth a shot.
WhatAmIDoing
Year and Model: 1998 S/V70 T5M
Has thanked: 104 times
Been thanked: 105 times
Post by WhatAmIDoing »
Rotate tires and check pressures as well, just a 1psi difference can cause a pull to one side (can also be used to fix a pull).
Even when the alignment shop gets her to drive straight, there's always a pothole lurking around the corner waiting to put an end to that.
'98 S70 T5M - 323,000mi - awaiting heart transplant :shock:
'99 S70 "AWD" - 220,000+mi - gone :cry:
Knows enough to be dangerous :wink:
wizechatmgr
abscate wrote: 20 Mar 2019, 02:44 Oh crap, wcm. At least you don’t have to JB weld your brake linings back on...
It's on my to-do list... =P
abscate wrote: 19 Mar 2019, 12:02 Last college drop off....Elizabeth still has the character marks from where 6 year old Caitlin shoveled snow off with an ice scraper
Hit 228000 today. Three days around metro Philly. Tough roads down here. I see why you Guys’s get 100k on your suspensions, max
