Can you switch door lock cylinders between driver and passenger side Topic is solved
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
volvo240student
Year and Model: 1993 240
Has thanked: 6 times
Post by volvo240student »
My driver side lock cylinder is I believe so worn out that on the last breath...to unlock the door I have to wiggle my key and pray for minutes in hope that the doors will open :)
Can I replace lock cylinder from passenger door to driver door? As I never use passenger door lock anyway.
Thank you
93Regina
Year and Model: 93:240/940
Been thanked: 65 times
Post by 93Regina »
volvo240student wrote: 18 Mar 2019, 17:27Can I replace lock cylinder from passenger door to driver door?
Well student, research will assist in your knowledge pursuit.
So, we start at ebay, and examine these photos.
And then do some Google searching for "volvo key lock," we come to this site.
So, your homework is to determine, and show us, if there is a difference between locks on left/right front doors.
volvo240student
93Regina wrote: 18 Mar 2019, 20:50
hahaha thank you professor 93regina! yes, I did rush with question before researching more online, also if anyone reading this and has 1993 wagon version and wants to replace all the locks in the car to have the same key, you will need control cable to the shifter. so you will need to get 1993 version locks only. My little contribution to www university...
93Regina
Post by 93Regina »
volvo240student wrote: 18 Mar 2019, 22:47I did rush with question before researching more online
Your response neglected the answer seeked...consequently, "Just because you fail once doesn't mean you're gonna fail at everything." -Marilyn Monroe
Correct Answer:
lummert
Year and Model: 760 1988
Been thanked: 26 times
Post by lummert »
I installed 1991 Volvo 740 door locks on my 1988 Volvo 760 due to the type of door locks used on the 88-90 760. These 740 locks work just fine.
1988 Volvo 760 Turbo Wagon
jimmy57
Been thanked: 320 times
Post by jimmy57 »
The lock cylinders are the same only the levers for linkage have the R and L difference. Remove the E clip and swap levers and you're good to go.
volvo240student
jimmy57 wrote: 19 Mar 2019, 21:34 The lock cylinders are the same only the levers for linkage have the R and L difference. Remove the E clip and swap levers and you're good to go.
Thanks a lot !
volvo240student
I did this and it worked , for future DIY folks , just be careful when removing E clip, there is a tension spring there, so make sure to rotate the spring and set up tension on it as well.
