Can I replace lock cylinder from passenger door to driver door? As I never use passenger door lock anyway.
Thank you
Well student, research will assist in your knowledge pursuit.volvo240student wrote: ↑18 Mar 2019, 17:27Can I replace lock cylinder from passenger door to driver door?
hahaha thank you professor 93regina! yes, I did rush with question before researching more online, also if anyone reading this and has 1993 wagon version and wants to replace all the locks in the car to have the same key, you will need control cable to the shifter. so you will need to get 1993 version locks only. My little contribution to www university...93Regina wrote: ↑18 Mar 2019, 20:50Well student, research will assist in your knowledge pursuit.volvo240student wrote: ↑18 Mar 2019, 17:27Can I replace lock cylinder from passenger door to driver door?
So, we start at ebay, and examine these photos.
And then do some Google searching for "volvo key lock," we come to this site.
So, your homework is to determine, and show us, if there is a difference between locks on left/right front doors.
I did this and it worked , for future DIY folks , just be careful when removing E clip, there is a tension spring there, so make sure to rotate the spring and set up tension on it as well.
