Hello guys, my mechanic was going to replace the angle gear sleeve when he diagnosed my transfer case as dead, no oil left so the gears are destroyed.
How should I proceed?
should I rebuild it? Buy a good used one? Is there another option?
I'm kinda depressed since I don't have a lot of money and this seems to be one of the most expensive parts to fail on this car.
Thanks for your help
Car : V70 2.0 226hp AWD 1997 Italian model
Transfer case is shot Topic is solved
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 73 times
You can remove the main drive shaft, and there is a chance it will stop any noise/vibration. You can leave it like that. Also, there is the option to completely remove the drive shaft AND the transfer case (angle gear). I did this on my car years ago. The issue is that you need to create a system to hold the angle gear sleeve in place, so it doesn't leak fluid. For years I used two worm gear hose clamps linked together and tightened on the passenger's CV axle and pushed up against the angle gear sleeve to keep it in. Recently, a mechanic created a 3D printed model then had a machine shop create a holder for the angle gear sleeve.
Or like you said, you can have the case replaced, but it's not a great system, and expensive to fix. Likely other parts will eventually fail.
Bonne chance!
Bonne chance!
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
- Fiodor
- Year and Model: 1997 V70 2.0 T5 AWD
- Has thanked: 13 times
- Been thanked: 9 times
I think I'm going to try and replace it, the question is : good used one or rebuild mine?
1997 V70 T5 2.0 AWD with welded angle gear at 240k km
1990 740 Break (dead)
- Antoine240bk
- Year and Model: XC70 2.5T-2006 - 4C
- Has thanked: 12 times
- Been thanked: 30 times
Have you tried Bildelsbasen in Sweden? A good used one could be the option for this mileage car. Though the shipping cost aren't cheap.
https://en.bildelsbasen.se/?link=list&s ... =125103103
Volvo XC70 2.5 T AWD P2 B5254T2 - 12/2005 Four-C Previous : Volvo V70 P1 2.4l 20s 170ch B5244S 03/2000 - Volvo 245 GL Break 1979 B21 -LPG - Volvo 240 GL Break 04/1992 B230F (Daily for 14 years)
- jvl
- Year and Model: 2006 V70 2.4D
- Has thanked: 20 times
- Been thanked: 8 times
Wow! Congrats, Fiodor! I have been looking for a good used one for two years now. I accidentally bought the wrong one, my car is a 1999 but has 2000 specs, so a 1999 replacement didn't fit.
Where did you find yours? Thanks in advance and good luck on the install!
1999 V70XC - Sold at 250K miles
2006 V70 2.4D - bought at 190k miles and going strong
- Fiodor
I bought it on bildelsbasen, had to call in Sweden to get a quote for the shipping and they then made an order for me.
- Antoine240bk
Ah! Glad it worked with the shipping cost. I bought several things on there, always pleased.
