1994 850 N/A Manual won't start
Has thanked: 1613 times
Been thanked: 4078 times
Pull off the cap and rotor and clean them up and get a good spark
If you get a good spark and it won’t fire on ether, part it out or get a new engine
Aheadbeyond
Year and Model: 1994 850 N/A
Post by Aheadbeyond »
Didn’t mention this. New cap and rotor was the first thing I did. Gapped all the plugs at .028 and had good spark on all 5
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
Aheadbeyond wrote: 07 Apr 2019, 16:56 Pulled spark plugs put some stater fluid in. Didn’t even sputter.
You spray starter fluid in Air intake not the cylinders. By the time you get the plugs back in and the wires reconnected the starter fluid would be long ago dissipated.
Spray a three second burst of Starting fluid in the Air Intake hose, then crank immediately before the Starting has a chance to dissipate.
Active
Past
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
This ^^^.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Aheadbeyond
I tried this on my initial no start condition. I tried thru the spark plugs because it was suggested on an older post for a no start. I did spray it into the cap and poured it. But I will follow the suggested procedure now that I have gapped all the plugs to spec.
Just to verify.028? They were all at .040
Wanted to say thank you to everyone for their help.
Troy
0.028 inches , correct
