You may have both errors, switch and ABS module. Haven't had the switch cause the speedo to drop out but the ABS senor failing will cause that. Try to see what codes you can pull. If a speed sensor error shows up it will most likely be the ABS module.
When I had a failing module it gave all sorts of weird issues with whole speedo cluster.
A re-built ABS module is a good investment from our good friend Matty Moo at Mid-West ABS. Costs a little more, but he does an exchange process where you can have your module until the new one arrives, swap it and then return the old one. He will need the part number on the module. Go to his web-site for more info.
ABS light random and idle question
- Has thanked: 1850 times
- Been thanked: 1710 times
Re: ABS light random and idle question
vovo850
- Year and Model: 1995 850 glt
- Has thanked: 49 times
No problems with the speedo yet.
It's my understanding when the module goes it's because of cracks in the solder.
Not too hard to reflow solder.
1995 Volvo 850 GLT N/A automatic wagon
- Has thanked: 292 times
- Been thanked: 765 times
Agreed, many have the soldering skills (but I don't). But opening and closing the case without butchering it is part of the challenge, check out ways others have figured out how to get that done. Maybe get one from a junk yard to try on. Or get a JY one and swap it in and be done (for a while)!
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- Has thanked: 1505 times
- Been thanked: 3818 times
You need a serious solder iron, not a circuit board one, like a 200 watt Weller. It’s about half the price of a good tested unit from Matty
Matty Moo
- Year and Model: 850, 1996
- Been thanked: 30 times
He has a 95, it's a different abs system. It doesn't have the failure issues like the 96 and up.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
