P2111 After O2 Sensor Replacement
XC70Rider
Year and Model: 2007 XC70
Has thanked: 35 times
Been thanked: 41 times
Re: P2111 After O2 Sensor Replacement
Post by XC70Rider »
I paid $35 for that harness from a different Volvo store and the tool wasn't included
https://www.volvopartscounter.com/oem-p ... e-31409380
Just need to unwrap the OEM harness and cut a few zip ties then reverse what you did. Disconnect both battery cables first. Being an Electrical Engineer for 20+ years it was easy & quick job.
ChrisRicc
Year and Model: 2004 V70R
Has thanked: 3 times
Post by ChrisRicc »
As an architect, I don't benefit from your experience. I think I'll try the replacement, though, despite my reticence. I've been shade-treeing on Volvos for a few years and am gaining a little confidence over time. Thanks for your direction.
RickHaleParker
Been thanked: 958 times
Post by RickHaleParker »
XC70Rider wrote: 08 Apr 2019, 19:11 I didn't splice the wires but replaced them all leading back to the ECM.
Did you need a Pin Extractor to get the old wires out of the ECM connector? If so, did one come with the kit?
XC70Rider
Post by XC70Rider »
RickHaleParker wrote: 09 Apr 2019, 00:49
Yes I used my pin extractor to get the wires off the ECM connector. Before I got this 8 piece pin extractor tool I used paper clips to extract wires.
XC70Rider
Post by XC70Rider »
ChrisRicc wrote: 08 Apr 2019, 21:12 As an architect, I don't benefit from your experience. I think I'll try the replacement, though, despite my reticence. I've been shade-treeing on Volvos for a few years and am gaining a little confidence over time. Thanks for your direction.
With good hand skills you could do it yourself. Similar to doing the timing belt you need to get the PS and coolant reservoirs out of the way. Pop off the top piece, pop out the center case, remove the fan and you can use the ECM extractor to remove both modules. IIRC the base connector was mounted with 10mm bolts. After removing the base there is very little clearance room to move it around. You want to first move it back then bend it slightly towards the engine. I removed the ETM loom back to the ECM connectors to know which wires needed extraction.
RickHaleParker
For those of you that don't know what Pin Extraction is, what you need or how to do it:
You can get the Pin Extraction Tool sets on eBay.
[youtube][/youtube]
ChrisRicc
Post by ChrisRicc »
Update. Took a few days, but I thoroughly cleaned the throttle body. Sad to say, to no avail. Still starting fine and then following shut down and restart, throws P2111 code and jumps into limp mode. So, I guess next stop is harness replacement. RickHaleParker, I'm concerned about fitment regarding the harness you referenced a number of posts ago. Is there a difference in the harness for V70 and V70R?
They've listed the following:
Application: For Volvo
2002-2005 Volvo S80 Non-Turbo
2002-2009 Volvo S60 Turbo
2003-2005 Volvo C70 Turbo
2002-2007 V70, XC70 Turbo
2002-2005 Volvo S80 Turbo
2003-2006 XC90 Turbo
Has thanked: 1498 times
Been thanked: 3810 times
Chris... you May be able to sort this by going to one of the several Volvo web store sites, entering your VIN, and pulling your part numbers there.
RickHaleParker
R stands for Refined, it is a performance trim level not a different car.
ChrisRicc
Post by ChrisRicc »
RickHaleParker wrote: 14 Apr 2019, 16:44 R stands for Refined, it is a performance trim level not a different car.
After a quick review of specs, it appears the throttle body across the Volvo L5 spectrum is identical, requiring, I would imagine (Forgive my ignorance RHP) the same harness. Have I deduced this properly? Should have done a little checking before requesting info from this forum. Apologies, too much going on this weekend, not the least of which is an uncooperative car.
