P80 Positive Temp Coefficient Nipple "PTC VALVE" To drill, or not to drill
Has thanked: 1497 times
Been thanked: 3809 times
I sit wiser in the end to suffer the slings and arrows of outrageous Crankcase pressure on the PTC Nipple?
This thread is for discussion on drilling, cleaning, and both on high mileage Volvo P80 engines
Volvo says clean every 60k
Excellent teardown thread here by Lee
https://www.matthewsvolvosite.com/forum ... =1&t=68898
One jerks opinion
The PTC Nipple
The PTC (Positive Temperature Coefficient) Nipple is just a hole, or Orfice nipple , to use the Volvo term. Its often mistakenly called a valve as it has an electrical connection, but that is just a heating element to keep the sludge from condensing and blocking it. It is a valve in the sense that it regulates vacuum to the Positive Crankcase Ventilation system, but it does not open and close like most think of a valve.
It is often drilled out, when in fact it is a required cleaning maintenance item every 60k miles on a new car, and (my recommendation) 30k on an old Volvo.
The reaction to "Hey the PTC is clogged, lets drill it out" should be "Why didn't I clean this per schedule?"
No judging here.
:D
Rattnalle
Has thanked: 20 times
Been thanked: 133 times
Post by Rattnalle »
Volvo put it there for a reason. Don't mess with it other than making sure it works by cleaning it.
My two cents.
PS that goes for things like cats and other stuff as well.
I could not find the PTC Nipple as a separate part - it does come with the Air Hose (Snorkel)
9186200 9445351
Danonly55
Year and Model: 1996 850 sedan
Has thanked: 23 times
Been thanked: 4 times
Post by Danonly55 »
Can this part be accessed without removing the intake manifold?
2014 Ford 3.5L ecoboost XLT
1995 Volvo 850 wagon GLE
Life is tough, but it's tougher when your stupid'
" John Wayne
ZionXIX
Has thanked: 64 times
Been thanked: 194 times
Post by ZionXIX »
Mine didn't even need to be drilled. It just popped out with a little prying.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
Danonly55 wrote: 16 Apr 2019, 07:20 Can this part be accessed without removing the intake manifold?
Yes, it sits at the bottom of the intake elbow, just before the turbo inlet.
The concept of drilling it out is to help vent crankcase gasses back into the intake a little easier. Usually the PTC itself is able to be removed with some prying, no drilling required for removal.
Has thanked: 292 times
Been thanked: 765 times
I first posted these in ZionXIX's thread viewtopic.php?f=1&t=84698. It's been 18 months now, with no ill effects on my 95 R.
The PTC is not available separately as a replacement part, good news is you will almost never need a new one, there's nothing to break or wear out. Great junkyard part in that sense.
The grommet for the base of the PTC is available separately from Volvo as part number 3507985, about 4 bucks. Very worthwhile to replace that!
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6 :shock: 153k
Yes, it is not located near the intake manifold it is down low near the brake booster at the firewall. And non-turbo cars like yours do not have a PTC. You may be thinking of the flame trap orifice specific to NA cars, which can be accessed by removing the air intake from the front grill and/or the air filter box for full access,.
'06 S60 R, 197k
Chuck W
Year and Model: 97 854 T5
Has thanked: 96 times
Been thanked: 333 times
Post by Chuck W »
erikv11 wrote: 16 Apr 2019, 09:00
Thanks for that PN. When I did the PCV refresh on both cars, that grommet was pretty soft and I wondered if a replacement was available.
