hey forum,
so looks like someone had the tcv lines hooked up wrong and I'm trying to piece together correctly.
I have the diagram in front of me and i can't figure out where the red line (part 20) plugs into.
diagram: http://www.volvohowto.com/volvo-850-tur ... es-diagram
Thanks
96 850 turbo TCV Line diagram help
jakethesnake
- Year and Model: 1996 850 Turbo Wagon
- Has thanked: 2 times
tardcart
- Year and Model: 96 850t. 93 940t
- Has thanked: 3 times
- Been thanked: 37 times
that is the compressor bypass line it goes over to the the intake manifold tree. It sends boost pressure over to open the CBV mechanically depending on the spring installed, 8 pounds of boost stock. its function is to vent boost if you suddenly see a cop during high boost but before the waste gate can dump.
- Has thanked: 1497 times
- Been thanked: 3810 times
Thanks for correcting my fubar post.tardcart wrote: ↑22 Apr 2019, 20:15 that is the compressor bypass line it goes over to the the intake manifold tree. It sends boost pressure over to open the CBV mechanically depending on the spring installed, 8 pounds of boost stock. its function is to vent boost if you suddenly see a cop during high boost but before the waste gate can dump.
