Head gasket repair......1999 v7xc
V70xc1999
Year and Model: 1999 v70 c.f. 2.4 Tu
Post by V70xc1999 »
Well I need to know a cpl things...
First off I have oil in my coolent not a whole lot but enuff to turn a darker green.
No colent in oil... as what I can see now.
I need to know what are the odds of it being a cracked head and not the gasket?
I am thinking when I have it torn apart I can check with this spray that finds cracks.
So my 2 main questions
what kit to get for the head gasket job
What brand
MAHLE....ITM....FELL PRO....BECK ARNLEY
And any recommendations on finding a crack in the engine ..
..what spray kit to buy? iv seen a few.
..is this the best way? I am tearing it down anyways and dont have presure tester. Thanks guys
Been thanked: 4068 times
Let the collective brain chew on this for a week, but in my recollection gaskets outnumber head issues by 50:1 - its a good bet it is just gasket.
Of course, once the head is off, you check it for being true and skim if required.
V70xc1999
Post by V70xc1999 »
Thanks what brand gaskets should I get?
Victor Raines....Fellpro....ITC....Mahle
All that labour? OEM Volvo.
It will be about $70 if you have the right one.
V70xc1999
Post by V70xc1999 »
Ok I can not afford to go volvo o.e. so my options are Victor ...or fellpro... Iv seen good result on some forums with these......the ? Is wich one should I get?
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Victor Reinz.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
V70xc1999
Post by V70xc1999 »
Thats what I just ordered about 3hrs. ago!!!!! Thanks
V70xc1999
Post by V70xc1999 »
One more thing what is the cheapest stuff that works good to inspect for cracks after I get it all torn down?
Has thanked: 311 times
Been thanked: 817 times
This year has the biscuit oil cooler, or the one in the radiator?
Still I would probably try compression testing the cylinders, some more poking around before disassembly if all you know so far is that there is oil in the coolant. Compression tester is free to rent from most auto parts stores
