Air pump '98 S70
MrAl
Year and Model: v70, 1998
Has thanked: 83 times
Been thanked: 73 times
Post by MrAl »
Hello there,
I have a 1998 v70 and mine does the same thing and always has since i got the car back some years ago. Is it normal? Well i cant say if it is normal for this make/model/year car in general, but i can say that it is normal for my particular car because i've always seen this behavior since i've had it with some variations as explained below.
It seems to be random though. Sometimes when i get to the first stop sign on my way out somewhere it comes on, sometimes not. Sometimes at a red light it comes on, sometimes not.
If i had to guess, and this is just a guess, it may be checking the system at random times under different conditions, and if it saw a problem at some point it might repeat the test under the same conditions. When i had trouble with my air pump i noticed it came on a lot more after i fixed the problem, but now it is much less.
Then again it could be that it comes on for some other reason because it detected something else that the air pump is used for.
Has thanked: 312 times
Been thanked: 818 times
Thanks MrAl, that is helpful to know.
RickHaleParker wrote: 03 May 2019, 04:08
abscate wrote: 03 May 2019, 03:22 Can we agree it’s a common occurrence, without the judgemental “ normal” or “abnormal”?
Clearly not unheard of but not enough data to declare it common. ...
The data are there, that is the point of my posts. Dogmatism does not trump empiricism.
I doubt it is related to brown out as common as it is, I think it is part of the routine.
Has thanked: 1611 times
Been thanked: 4074 times
Source code of the ECM with the run conditions are the only way to firmly put the design intent question to bed. Ill bet there as many cars that don't run SAS after start as not; of course, a plethora of variables muddy the water as to why this happens.
Hey, I used a semi-colon!
Or we could ask jimmy57!
MrAl
Post by MrAl »
erikv11 wrote: 03 May 2019, 08:05 Thanks MrAl, that is helpful to know.
Hi,
That's an interesting point about the brownout, but since i had my new battery i dont see any difference that i can notice. I know there was a difference in battery voltage too with the old battery compared to the new one because i keep an analog meter connected at all times. When i turn the heater on i see the voltage dip and with the old battery it would dip really low but with the new battery it dips only slightly. But through it all the air pump seems to act the same.
I dont have any data on how much the battery voltage dip affects the computer though so all i can do is state my experience with it so far. i have had the new battery for a couple months now.
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
MadeInJapan's observations in the other post could be the results of several things.
1. It could be the ECM sending a spurious command.
2. As I stated earlier, it could be the +12V on the coil shorting to another +12V.
The source of this could be right there at the pump relay.
A. Sockets can develop intermittent shorts.
B. Relays can develop internal intermittent shorts.
There is a +12 for the switch pole at the relay.
3. Wiring looms can develop intermittent shorts anywhere along their length.
My '98 C70 SAS does not activate after the initial warm up.
Active
Past
RickHaleParker
MrAl wrote: 03 May 2019, 11:40 I dont have any data on how much the battery voltage dip affects the computer
It may not be the voltage level, it could be the slew rate of the fall or rise.
Some digital events are triggered by the Signal edge.
Active
Past
RickHaleParker
I would start with tapping on the relay to see if the pump comes on.
Inspect the socket and looms for damage.
Active
Past
crlande
Year and Model: 240DL;850;S70
Been thanked: 36 times
Post by crlande »
That is my game plan, mess with relay and look for vac leaks. Quite the informational topic. Detailed explanation of system function, electrical tech, past posts, philosophy, and punctuation excitement. All from some the heavy hitters on MVS.
