V8 Balance Shaft
Roger_850T
Year and Model: 854T 1995
Been thanked: 26 times
Post by Roger_850T »
jimmy57 wrote: 02 Jan 2019, 12:28 They didn't ask me but it seems a better thing to do in the rear bearing saddle area is to take a Dremel or other tool with a burr and grind a groove down the bottom middle. There is a hole in the balance shaft case that goes into the hollow cavity already. If debris blocks the drilled one why have the water go to the mid point of bearing before it can run through the ground reliefs on saddle sides.
Hi Jimmy57,
Following up on this... Having completed this step, I don't think this clearancing is for drainage. The new hole will drain the space nicely. I think this clearancing is to allow the new bearing to slip in a little easier when you press it in. It was pretty tight, even with this done, and I couldn't get it to test-fit without removing this material.
Plus, the material removed does not actually go all the way through to the end. It's just removed where the bearing sits, and the aluminum that the outer race is flush to will still prevent drainage, so I'm certain it's not for drainage.
Cheers!
Roger
11 XC60 137k
08 V50 Project... Still in pieces
05 XC90 V8 213k
95 854T 350k Still my favorite daily driver
02 V70 186k+ Gave to my daughter, still going strong
03 S80 111k (crashed, but driver walked away unhurt)
93 945T 217k (gone to be parted out)
87 245 300k+ sold, still going afaik
84 264 Diesel, RIP at 160k
78 242 manual everything.
73 P1800ES, fun until the rust set in...
Roger_850T
It's back on the road. Hooray! :D It took a while, primarily because we had a backup car, (it was merely inconvenient, not urgent,) and life gets in the way. All told, it took me 7 months. But that 7 months included new floor throughout the main level of the house, a day job, life with an active daughter, and just not working on it when getting home from work. But it's done!
The biggest problem was that I tore the rear valve cover gasket, and didn't realize it. I had to squeeze it in between the camshaft and the rear wiring loom, and didn't realize I tore it until the first test drive. On that test drive, I lost a quart of oil in 10 miles, all on to the rear exhaust manifold. (Oops.) I had to remove the intake manifold and rear valve cover to discover exactly what I had screwed up, then wait for parts (again) before getting it re-assembled a second time.
I'll post more details in the next couple of days, but I thought I'd share the good word that it's running again. And yes, I missed the V-8!
Roger
11 XC60 137k
05 XC90 V8 213k
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
Glad to hear it's up and running!
Roger_850T
Here's the list of parts that I ended up buying for the balance shaft bearing replacement. It's a word doc, because I couldn't paste from Excel and have it formatted reasonably nicely. Altogether $1,195 in parts.
There were a number of parts that I bought above and beyond what was minimally required for the work. They replaced wear items that were reasonable to replace while I had it all apart and they were easy. They were:
Water pump (with 140k on it)
Upper/Lower Radiator Hoses (140k on them)
Fuel Injector Seals (140k on them)
Aux belt and idlers (with 35k on them)
Spark plugs (had 35k miles on them)
Front main crankshaft seal
I ended up replacing the rear valve cover gasket twice, because I managed to tear it when squeezing it under the wire loom. I was more careful the second time around!
Roger
11 XC60 137k
05 XC90 V8 213k
bmdubya1198
Great info, thanks for posting that list! I'm going to need to take care of the timing cover gasket on my mom's V8 soon, and I want to replace everything I can while I'm in there. At 153k miles, most anything in that area is due for replacement anyway.
allrotor13b
Year and Model: 2005 XC90 V8
Post by allrotor13b »
Hi, i was wondering if you could help me find this ground's home: It's the one that lands on the right strut tower under the power steering and coolant reservoirs.
i hope it isn't going somewhere i have to remove a head to land :(
bmdubya1198
allrotor13b wrote: 11 Jun 2019, 22:29 Hi, i was wondering if you could help me find this ground's home: It's the one that lands on the right strut tower under the power steering and coolant reservoirs.
The image link isn't working. Is it on Google Photos? Try sharing it with the "share" option and select "create sharable link".
ggleavitt
Year and Model: 06,08 XC90 V8
Has thanked: 26 times
Been thanked: 134 times
Post by ggleavitt »
Not sure if this is what you're looking for-
XC90 V8 Ground PassSide_1.jpg (279.12 KiB) Viewed 2461 times
XC90 V8 Ground PassSide_2.jpg (193.69 KiB) Viewed 2461 times
Have a link with some more photos in the even it's helpful- https://goo.gl/photos/tcLSKkYEp6KqkbaR9
allrotor13b
ggleavitt wrote: 13 Jun 2019, 13:34 Have a link with some more photos in the even it's helpful- https://goo.gl/photos/tcLSKkYEp6KqkbaR9
It's this one:
Thank you very much!
Roger_850T
bmdubya1198 wrote: 10 Jun 2019, 21:51 Great info, thanks for posting that list! I'm going to need to take care of the timing cover gasket on my mom's V8 soon, and I want to replace everything I can while I'm in there. At 153k miles, most anything in that area is due for replacement anyway.
How's the timing cover gasket? If you're going that far, you might as well do the timing cover as well, including the front crankshaft seal.
What year is your mom's V8? 2005 was the bad year for the balance shaft bearing, and supposed to be fixed 2006 and later. But if you're in there that far, it's worth at least planning to shine a light down at the back of the bearing and inspecting. Having done it once, I'm a little cynical about the back bearing lasting "forever", although people don't complain about it, so maybe it does. But I'd at least look. If your mom's engine IS a 2005, you should seriously consider "drilling the hole" if you're in there that far.
Feel free to ping me if you have specific questions. Email is best, as sometimes it's intermittent when I'm online.
Roger
11 XC60 137k
05 XC90 V8 213k
