DIY: Oil Pan/Sump O-Ring Replacement 2000 XC
This topic is in the MVS Volvo Repair Database » Oil Pan/Sump O-Ring Replacement 2000 Volvo XC
Wreckerct
Year and Model: 2006 S80 AWD
Re: DIY: Oil Pan/Sump O-Ring Replacement 2000 XC
Post by Wreckerct »
volvofixer1000 wrote:Well, well, well!!!!!! I almost got it. I thought your job looked very much like mine, but from what I found out, the vehicle that I have is slightly different.
I have a 2006 S40 and I just found out that the A/C compressor has to be at least loosened , I just don't know if there is enough room to push the compressor to the side and drop the oil pan.
Has anyone done this job on this model? if so please let me know where I can read about it.
Thank you
Thank you all for the information - I am ready to tackle this job tomorrow on my 2006 S80 turbo AWD.
When I remove the front engine mount behind the passenger tire will do I have to remove anything else like the compressor or drop the subframe?
the transmission mount does not appear to be in the way and there are no lines under the pan as in earlier models.
Anything you learned from your 2006 would be helpful....
Thanks
Kp
BenF
Year and Model: 2001 V70 XC
Post by BenF »
Resurrecting an old thread here, I'm getting ready to do this on an 01 xc. Why it is required to use ramps not a floor jack to put jackstands under the door rails ?
Tks
LOB
Year and Model: 855 GLT 2.5T
Has thanked: 10 times
Been thanked: 16 times
Post by LOB »
I replaced my oil sump without touching the engine mounts. At 70K miles they where probably less worn making space enough to remove the oil pan without anything more than bending the power steering pipes. However I wasn't smart enough to change the O-rings.
xHeart
Year and Model: 2.0/3.2
Has thanked: 113 times
Been thanked: 115 times
Post by xHeart »
BenF wrote: 01 May 2019, 08:02 Resurrecting an old thread here, I'm getting ready to do this on an 01 xc. Why it is required to use ramps not a floor jack to put jackstands under the door rails ?
Tks
You can raise it with floor jack and set it on jack stands. PRACTICE SAFETY!
A recent 2001 V70XC oil pan and more project viewtopic.php?f=9&t=61449
BenF
Post by BenF »
So I just got done, thanks to the op for the excellent write up. My 2001 xc is simpler. Didn't even see the power steering lines in this one and I didn't have to mess with the engine mount. It only took a few seconds of wiggling to get it out. My o -rings looked fine and my pick up filter wasn't really clogged. I think someone had already done this job. None of the bolts were too hard.
KDAKC
Year and Model: 2001 v70 T5
Post by KDAKC »
washdup wrote: 19 Jul 2010, 23:02 Excellent writeup! After reading it, I'm glad I had a shop do the job for my car, but someone with more inclination could sure benefit. For anyone wondering, this job will often take care of "ticking" in the lifters. In my case, the ticking would occur if the oil level was a little low. The dried out o-rings make for poor suction of oil up the tube from the pan, so the lifters can get a bit starved of oil.
I've got a bag of o-rings and gaskets and my oil pan on the floor of my shop. Remembering having to re-do the nightmarish heater core replacement, I'm looking at this stuff thinking, "don't move until you're sure you've got it right." Your write-up gave me the confidence to proceed. Thanks!
smacknab
Has thanked: 97 times
Been thanked: 43 times
Post by smacknab »
Anyone know if the process is the same for a m56 transmission? The mating of the oil pan and transmission makes me worry a bit that I don't have the right seals etc
07 V50 T5 AWD M66 ~146k miles
E Showell
Year and Model: ‘07 S80 3.2
Has thanked: 37 times
Been thanked: 111 times
Post by E Showell »
I did the O rings in my '99 V70 and it didn't help the lifter tick.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
JimBee
Has thanked: 25 times
Been thanked: 42 times
Post by JimBee »
smacknab wrote: 23 Apr 2020, 13:44 Anyone know if the process is the same for a m56 transmission? The mating of the oil pan and transmission makes me worry a bit that I don't have the right seals etc
Your photo is looking at the back of the engine. There are no seals back there. All the seals at the front.
Has thanked: 1505 times
Been thanked: 3818 times
All data says there are 2 bolts that go from transmission in to bosses in the oil,pan. These don’t need sealant
