Power loss
Barledge
Year and Model: 2002 Volvo S80 T6
Power loss
Post by Barledge »
2002 S80 T6, bought e weeks ago with 195k . First started with a El.power service required and battery light, found out someone put a 140 amp alternator on it so I replaced battery and 160 amp alternator Bosch. Problem cured. But had no power, codes for Cadillac converter something about bank 1 and bank2 . And throttle body sensor, I replaced the whole throttle body and sensor, but was also told it needs to be reprogrammed is this true???? Drove about 80 miles engine light back on, I reset it inside and no more codes, YET anyway, but still can't get above 4000 rpms. Any suggestions? I'm stuck with this car dont have a choice but I do love it.
tardcart
Year and Model: 96 850t. 93 940t
Has thanked: 3 times
Been thanked: 37 times
Post by tardcart »
I don't know your year, but the bad alternator will set lots of unrelated codes. You probably should just have cancelled them and not replaced anything, now that you have replaced components you may have to have them programmed. You could try putting the old ones back.
Barledge
Post by Barledge »
I've owned Volvo's before and I am unfortunately very familiar with working on them , it runs good on the highway and street but at idle and park it Boggs rough idle now have all these misfire codes. This car was very well maintained by 1 owner for 16 years not sure what but it was always maintenanced by dealership but he changed 1 thing wrong and threw it all off is my assumption.
