jvl
Year and Model: 2006 V70 2.4D
Has thanked: 20 times
Been thanked: 8 times
Re: What did you do to your Volvo today? (now Sticky!!)
Post by jvl »
Finally got VIDA to work!
So glad that I can now just lookup part numbers and put them in google when I need to buy parts! No more comparing different parts online and wondering which one fits my car! :D :D
1999 V70XC - Sold at 250K miles
2006 V70 2.4D - bought at 190k miles and going strong
ZionXIX
Has thanked: 65 times
Been thanked: 194 times
Post by ZionXIX »
jvl wrote: 05 May 2019, 14:00 Finally got VIDA to work!
Is that a difficult task?
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
ZionXIX wrote: 05 May 2019, 17:35
It can be. It wasn't too challenging to get it to work on my Windows 10 laptop (which is known to be a bit of a challenge) but RickHaleParker's patch got me up and running pretty quickly and easily!
Saab TIS2000 was much more of a challenge to get working properly. I had to do that on one of my old XP desktops since that absolutely does not work on anything newer.
WhatAmIDoing
Year and Model: 1998 S/V70 T5M
Has thanked: 104 times
Been thanked: 105 times
Post by WhatAmIDoing »
To celebrate my S70 hitting 270k miles, she got a full timing service. And I'm glad I did it know. A good friend helped me out (if you read this you know who you are THANKS!!) and made this job go a lot more smoothly. PO claimed he did the timing belt and cam seals around 200k miles, and once we got the cover off we discovered a true hack job. Cam sprockets were on wrong making lining up the timing marks impossible. Once we sorted that, we found an OE replacement waterpump with tons of old gasket left behind. Timing belt was starting to crack. But the most concerning of all, the hydraulic tensioner was badly corroded and the tensioner pulley was very much on its way out (stiff and screeching). So definitely glad I got this job done today. And of course to add insult to injury, the new Volvo waterpump gasket I bought arrived broken in two places (my fault for not inspecting it upon delivery). Unfortunately I needed the car and we only had one choice but to use it. Slathered it in Permetex seelant, installed the water pump to torque spec, and prayed to the Volvo gods for no leaks... prayed a lot.
'98 S70 T5M - 323,000mi - awaiting heart transplant :shock:
'99 S70 "AWD" - 220,000+mi - gone :cry:
Knows enough to be dangerous :wink:
jvl
Post by jvl »
Well, no, it is not difficult but does require many specific steps. I had to setup a virtual machine that runs Win7 Pro SP3 and then install Vida + required patches. So, not difficult, but time consuming nonetheless!
Has thanked: 1505 times
Been thanked: 3818 times
I rolled Evita the S70 from ALB to Smith College and back, then to PHL and back, then to Smith and back on Sunday
Elapsed miles was 960, 30 mpg. I still have cooling group refresh to do, and dash BSR repair.
yanga001
Has thanked: 59 times
Been thanked: 110 times
Post by yanga001 »
Replaced the top motor bushing with a home made clamp, car is once again smooth and dash noises have vanished.
2008 S60 2.5T Auto (Sold)
bmdubya1198
Picked up an egg crate and a set of jewels for the R today. Unfortunately I can’t drive her right now due to the bad ETM. I’ll just have to spend the money on a Xemodex once the S90 sells.
Jewels will go on once I polish up the lenses and fix the pigtails that somebody chopped off. But the grille is on at least!
Appreciate that, June and I will like that view....
bmdubya1198
abscate wrote: 09 May 2019, 07:35 Appreciate that, June and I will like that view....
You guys will probably be getting a better view of my dual exit exhaust. Polish it while you're back there!
