1999 V70 T5 DIY Front Caliper 8111102 8111101 DIY in 50 minutes!!
Has thanked: 1505 times
Been thanked: 3818 times
Re: 1999 V70 T5 DIY Front Caliper 8111102 8111101 DIY in 50 minutes!!
6 years and 95,000 miles later, just replaced rotors and pads again on this car
Cant get good quality parts anymore.
j-dawg
Year and Model: 1999 V70 T5
Been thanked: 33 times
Post by j-dawg »
How are the calipers holding up?
Worth noting: the factory big brakes use the same calipers and pads as the standard items. Makes for an easy upgrade.
j-dawg wrote: 15 May 2019, 23:07 How are the calipers holding up?
I still that upgrade just new caliper brackets and rotors (. 280mm To 305mm)?
JimBee
Has thanked: 25 times
Been thanked: 42 times
Post by JimBee »
As pointed out, those fronts are easy, if as abscate says, the flex hose nipple hasn't siezed in the caliper. Nice writeup. Everybody still running one of these cars is going to be doing this in the near future.
That was a good price on the rebuilt ATE caliper. Is the piston fully chromed?
j-dawg
Post by j-dawg »
abscate wrote: 16 May 2019, 04:19 I still that upgrade just new caliper brackets and rotors (. 280mm To 305mm)?
I think the factory big bois are 302mm. Brackets, rotors, and hoses. Super easy upgrade when it's brake time, unless your hoses are seized in place like mine were.
DeadEric
Year and Model: 1996 850 Turbo
Has thanked: 2 times
Been thanked: 12 times
Post by DeadEric »
Yeah, screw in brake hoses, it's an odd euro thing that you don't see often. Besides euro cars I've only seen it on Mazda rear brake calipers. Everything else is banjos.
Nice work on 50 minutes. I get paid 1.4 hours to do calipers and .7 to flush the brake system.
Pressure bleeding is the way to go for quick, easy and thorough. The equipment can get spendy if you don't do it often. Gravity bleeding is free, just don't forget to pump the brakes and bleed out the air or let the master go dry.
JimBee wrote: 16 May 2019, 18:43 As pointed out, those fronts are easy, if as abscate says, the flex hose nipple hasn't siezed in the caliper. Nice writeup. Everybody still running one of these cars is going to be doing this in the near future.
That was six years ago upthread. My last set of Cardones rusted to shinola and seized in 2 years. We have to qualify brands my name and time now.
Adding some wisdom of ages to this thread. If you let propane fire play on the hose to caliper union for 30 seconds , careful watching the plastic part for melting, it will greatly ease removal. Focus the flame on the metal on the caliper , not the hose joint itself
…and more wisdom…if I had gone with FCP I would have free new calipers by now.
Sadly, my BAP GEON store closed in Albany a few years ago.
