Rotor size question.
TheOtherside
Year and Model: 1998 V70R
Has thanked: 55 times
Been thanked: 5 times
Post by TheOtherside »
I'm having a buddy that works for US Venture price out some rotors and pads and he's getting multiple diameters for both front and rear.
Does someone know what the sizes are for front and rear rotors on a 1998 V70R?
THANKS!
98 V70R
13 Flex w/EcoBoost
Has thanked: 1500 times
Been thanked: 3812 times
The two P80 sizes are280mm and 305 302mm
Plug the VIN Into the Volvo web store And it should pop out the right part for you.
I believe the R models all got the 305 302mm rotor in 1998
TheOtherside
abscate wrote: 22 May 2019, 02:05 The two sizes are280mm and 305mm
I believe the R models all got the 305mm rotor in 1998
Why thank you my good sir!
98 V70R
13 Flex w/EcoBoost
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 304 times
Been thanked: 517 times
Post by bmdubya1198 »
1998 R should have 280mm up front. I don't think the R got 302mm front rotors until 1999 or 2000.
I believe the R models all got the 305302mm rotor in 1998
Needs verification. Never trust any memory over 30
Clemens
Has thanked: 473 times
Been thanked: 219 times
Post by Clemens »
If you have the 302s be sure to get the matching pads. There seesm to be a difference.
Summer: 1996 855 R
Winter: 1994 855 T5M
Donor: 1995 854 10V
abscate wrote: 22 May 2019, 02:05 The two P80 sizes are280mm and 305 302mm
Whats 3mm between friends? Not much
More between brakes though.
:lol:
850 LPT
Year and Model: 96' 850
Has thanked: 331 times
Been thanked: 242 times
Post by 850 LPT »
Clemens wrote: 22 May 2019, 08:14 If you have the 302s be sure to get the matching pads. There seesm to be a difference.
Pads are the same. Caliper is the same as well.
The only difference is the caliper mounting bracket.
58' Porsche Diesel Junior
13' Honda Odyssey :oops:
TheOtherside
Thanks for everything guys. So the only real way to tell is to take them off and measure?
98 V70R
13 Flex w/EcoBoost
Almost an inch difference in diameter? Get a scale , man, and measure it.
Homemamde caliper (measuring kind) with a paint stick and two thin bamboo skewers
