2006 V70R head gasket leak -- weighing options
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 111 times
Re: 2006 V70R head gasket leak -- weighing options
So if I go the used mill route, what kind of compression test numbers should I be looking for in the used unit?
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
- Has thanked: 1505 times
- Been thanked: 3818 times
Should be in VIDA , isn’t the R engine unique in stroke/bore.....and therefore compression, too?
Found this in All-data, your science trained lawyer can do the MPa to psi conversion
- E Showell
Don't even know what units MPa refers to.
'95 855 auto (sold)
'95 855 auto (sold)
- E Showell
So roughly 160-190 psi.
'95 855 auto (sold)
'95 855 auto (sold)
Pascal’s are SI units of pressure.
MPa is 10E6 Pascals
1 atmosphere is 101,000 Pa, so 1MPa is about 10 atmospheres pressure.
I get the same numbers as you in psi
MPa is 10E6 Pascals
- E Showell
Anybody know whether I can stick that used mill, w/accessories on it, into the back of a P2 XC70?
'95 855 auto (sold)
'95 855 auto (sold)
- Has thanked: 292 times
- Been thanked: 765 times
Glad you're going the swap engine route, much easier and safer (less prone to failure) than doing the head work. Don't know about the transport question.
'06 S60 R, 197k
'07 XC70, willow green, 212k
'99 Camry V6
153k
'06 S60 R, 197k
'99 Camry V6
- RickHaleParker
- Been thanked: 958 times
Megapascal (MPa) = 1 Million Pasacls = 10 Bars.
1 Pasacl = One Newton per square metre.
1 Megapascal = 1 million Newtons per square metre.
1 Pascal = 0.00014503773801 pound/square inch (PSI)
1 Megapascal = 145.03773801 pound/square inch (PSI)
- MoVolvos
- Has thanked: 310 times
- Been thanked: 524 times
Would it be catastrophic or too dangerous to just try tightening the head bolts in sequence a quarter of a turn to see if the leak goes away or is minimized a great deal? Years ago I did that with 3 cars but each were leaking oil rather than coolant. 87 Acura Integra, friend's 88? Mitsubishi Galant & 88 Camry. Budget, time and mileage prohibited doing anything else but that. Did work for all 3 cars.
Neither but that is not going to fix a blown gasket. Once they blow they get damaged , so squeezing won’t fix them
It’s also wasted work to get to the head bolts, too.
