Hello Group,
I have '83 244 GL non-turbo. LH 2.0 Chrysler Ignition. The car stalled on me a few months ago, and knowing the fuel pumps had never been replaced, I replaced both fuel pumps and filter. Now the car will start after some cranking, and run fine at high idle. When I slow the engine to low idle, and put into gear, she will likely stall. I tested the MAF and get good Ohms. I have a new fuel pressure regulator, but not installed yet. Also, engine will not rev-up well. Sudden revving will result in hesitation.
Can ya'll help me with further troubleshooting? I'm going to install that regulator, but are there any other things to look at? I see an adjustable screw on the MAF, what does that do?
Thanks in advance for advice!
-Tom
83 244, Stalls when put into gear
- 93Regina
- Year and Model: 93:240/940
- Been thanked: 65 times
A pinch of starting fluid, directly into a throttle body port, would rule out a fuel pressure issue. If FPR is not holding or maintaining pressure, then hard starts will exist.
I don't recall what LH 2.0 does when AMM is unplugged, but you could do this test and see what happens.
- 1053 Views
Last post by dj_v70
- 439 Views
Last post by 1998XC70-AWD
- 2498 Views
Last post by MDK
- 12 Replies
- 4824 Views
Last post by EdRedSled
- 1104 Views
Last post by June
