Hello everyone, I have a 1997 850 and I can’ t keep the timing marks to stay put. I first aligned the marks on the crank and then the cam sprockets right on the money and lock the cams with my iPd tool.When I assembled all the new parts (idler,pump,tensioner), I then wrap the belt around everything and go to pull the pin on the tensioner and find that it keeps jumping about a tooth off when I go to rotate the crank. Should I align the crank and cams about a tooth off to compensate for the tensioner as it begins to re-extend after I pull the pins. This is driving me crazy, my bolts on the sprockets have not been touched . I have enclosed some pics
Timing Belt Marks Keep Moving
- RickHaleParker
- Been thanked: 979 times
Active
Past
Past
- ZionXIX
- Has thanked: 66 times
- Been thanked: 195 times
When I changed my belt I had to compensate by moving one tooth in the opposite direction so it would all line up after I released the tensioner. It took me about 10 tries to get right. Just keep trying.
- RickHaleParker
I think you are not getting the belt tight going counter clockwise from crank, intake and exhaust, when you pull the pin that slack is taken up and that is why you are one tooth off.zupta82 wrote: 27 Jun 2019, 08:06 I’m a little confused do you mean pry up on the roller tensioner arm thing and then pull the pin.
I loop around the crankshaft, pull tight and loop around intake, then the exhaust, then push the belt over the tensioner, pull the pin. You got to keep the belt tight through the entire process.
Active
Past
Past
- callahanoffroad
- Year and Model: 1995 850
- Has thanked: 16 times
- Been thanked: 53 times
This is a really good tipRickHaleParker wrote: 27 Jun 2019, 13:58I think you are not getting the belt tight going counter clockwise from crank, intake and exhaust, when you pull the pin that slack is taken up and that is why you are one tooth off.zupta82 wrote: 27 Jun 2019, 08:06 I’m a little confused do you mean pry up on the roller tensioner arm thing and then pull the pin.
- misha
- Has thanked: 155 times
- Been thanked: 432 times
You don't need cam locking tool at all.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- Has thanked: 311 times
- Been thanked: 817 times
(1) cam locking tool is probably making things worse, see my suggestion (3) below which can not be done with a cam lock tool
(2) use the standard procedure: always start on the crankshaft then proceed from the right (install belt counterclockwise). Pull the belt tight over intake sprocket, then over exhaust sprocket, etc.
(3) BUT after everything is perfectly aligned and ready to go but before you start putting on the belt, cheat both of your cam sprockets about 1/2 of a tooth to the right (clockwise). This will greatly simplify keeping the belt tight as you traverse through the sequence. Be careful, the exhaust cam wants to jump due to cam lobe pressure, be patient you can get it to sit where you want it.
(4) check the marks when you are done, make sure you rotate a full cycle of the crank by hand and check them again.
You will find suggestion (3) to be super useful!
Likely the angle of the pics is misleading. It's going to be off a whole tooth, and OP does say that in the first post.
- 1723 Views
Last post by darrylrobert
- 10648 Views
Last post by vtl
- 19 Replies
- 1752 Views
Last post by cn90
- 33 Replies
- 8329 Views
Last post by jking4020
- 9 Replies
- 5718 Views
