'99 XC - Need some additional brains here
wizechatmgr
Has thanked: 45 times
Been thanked: 129 times
Post by wizechatmgr »
Let's start out with the basics...
Known issues:
  • Both front spring seats appear to be toast, believe driver's strut bearing/mount is also near death
  • Rear turbo oil return seal is toast and leaking intermittently onto angle gear
  • Surging during braking that appears to be on driver's side - intermittent gentle almost inaudible thump at highway speeds - follows driveline speed increase/decrease
  • PCV likely should be done soon, as well as timing belt
Question:
Could the bad front spring seats be causing the thump at speed and surging at low speed braking? Suspect a warped rotor on driver's side due to previously incorrect tension on passenger's side axle nut (corrected) causing tracs to kick in driver's brake.
2023 Lexus RZ450e -66k
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
The bad spring seats will always make noise, really at any speed. I would not, however, correlate a surge during braking to them.
I guess I need a more detailed description of that phenomenon to hazard a guess as to where to start. Does it act like the engine actually revs or is it a loss of braking power?
Replacing the turbo oil return line seal on a XC is a real treat but it can be done. I think I actually pulled the passenger side axle and dropped the angle gear to do it on one of mine. On the other one I replaced it before I installed the new motor.
The rotor is super easy. I know there is big debate between Brembo and Zimmerman but I have had acceptable service and life out of the cheap auto parts store versions. Pads are a different story. I normally use Mintex Reds but OEMs are a great option, albeit a dustier one. Most of the auto parts store pads will squeal.
wizechatmgr
Sorry for the late reply,
There is just a tinge of a thump and vibration at speed that correlates with the speed of car movement while driving.
Surging on braking isn't RPM surging but rather it feels like a warped rotor to excess. Feels as if you're pumping the brakes...
I'm wondering if the rotor can get bad enough to cause both...
Has thanked: 1611 times
Been thanked: 4075 times
Have you rolled under and looked at both sides of the rotors?
wizechatmgr
abscate wrote: 28 Jun 2019, 19:23 Have you rolled under and looked at both sides of the rotors?
I likely need to look again. Planning on pulling both off and looking at them with a straight edge to them. My feeling is the driver's side is badly warped.
I’ve got two spares in the parts bin. We can probably straightedge them on the car, too.
wizechatmgr
So, turns out I found out part of this issue today while checking tire pressure.
I found a nail in the driver's front, which likely bled the air in the tire down a bit. Tossed some fix a flat in it for the moment and will work on a proper tire repair tomorrow when the local chain opens. Looks like it isn't in the side wall so it should be an easy fix. I'll have them check the passenger's front as well. This would explain some of the issues.
Doesn't fix what I believe to be the rotor. Looking at potentially checking this out next week while I have my mini-mechanics with me.
Driveway open here but I know I’m a bit far.
greg850r
Year and Model: a long list
Has thanked: 5 times
Been thanked: 26 times
Post by greg850r »
I wouldn't rule out a tire causing your symptom.
05 Cross Country wagon
99 C70 Convertible
96 850R wagon
96 850T wagon
96 850 GLT 5spd N/A sedan -wrecked, ouch
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
02 Sportster Custom -sold
Parts cars come and go
