OBD11 code P0192, 2004, V70
sony2000
Year and Model:
Post by sony2000 »
Code says fuel pressure sensor, low voltage. Check engine lite comes and goes. Tried ways to increase pressure. Cleaned contacts on sensor and battery for better ground. The next step and hardest, is to clean the contact of the sensor on the fuel rail to achieve a better grounding. Question is, does the sensor ground to the fuel injection bar? Canadian car without exterior fuel filter. 65,000 miles. Thanks for your help in advance.
sony2000
Year and Model:
Post by sony2000 »
Youngest parts dept. employe's reply: If the fuel pump is not working hard, the voltage may drop to 12.7V from the normal 12.8V, causing the check engine light to come on. If true, then there is a cause for rewriting the software!
sony2000
Year and Model:
Post by sony2000 »
Removed sensor and cleaned it. Now car has died a couple of times when the RPM is low. Does anyone know where I can get just the O ring for that sensor? Its bright blue in colour and about 1/2 inch in diameter. The colour probability denotes resistance to gasoline deterioration. Will call the dealer. They may keep them in their shop supplies. The valve is at the other end of the fuel rail. It may need an O ring as well! :roll:
sony2000
Year and Model:
Post by sony2000 »
Is it in the tank? Canadian V70 2004
sony2000
Year and Model:
Post by sony2000 »
Stalling was becomming more frequent. Changed fuel pressure rail sensor. Cost $250 CDN, $235 USD. It sends demands to fuel pump so it doesn't work at full speed all the time.
LoveMyS60
Year and Model:
Post by LoveMyS60 »
Volvo announced a recall for this part last month. See:
http://volvospeed.com/vs_forum/index.ph ... opic=79906
sony2000
Year and Model:
Post by sony2000 »
Thanks, LovemyS60. Will go over and get my refund. And Ford wants to sell off a winner, ....Volvo????
sony2000
Year and Model:
Post by sony2000 »
Fuel consumption is less. Has dropped from 10.8 liters/100kms. (the best it ever did prior) to 9.7liters/100kms. Summer tires and A/C on.
sony2000
Year and Model:
Post by sony2000 »
Dealer called to say the cheque is in the mail. Fuel consumption down to 8.5 liters/100 kilometers on a 94 octane gasoline. Thanks moderator!
sony2000
Year and Model:
Post by sony2000 »
The failure of the pressure sensor did not show up on the messages, and took a long time to turn on the check engine light.
88 Volvo 760T
90 Volvo 760T
94 Volvo 855T
99 Volvo C70
04 Volvo V70
04 Volvo S60R
