Hey All,
Just wanted to post about a recent issue I just had with a new-to-me 04 S60 2.4i
Car was driving excellently, without issue. No hesitation, stumbling, anything. But thew a CEL. Codes P0192 (Fuel Rail Pressure Sensor -low) and P0171 (Lean)
There was a recall on the Fuel Pressure Sensors on 03/04 S60s so I figured that would be causing both codes.
Replaced it with the $34 Rock auto Bosch 0261230109 and the CEL hasn't returned(2 weeks).
Just wanted to share my experience as I didn't get much info from 'P0192' searches. Hopefully this will help someone.
2004 S60 CEL P0192 P0171 FPS 30756098 Topic is solved
- DeadEric
- Year and Model: 1996 850 Turbo
- Has thanked: 2 times
- Been thanked: 12 times
P0171 "should not" be flagged by a fuel rail pressure sensor. I use quotes because p0171 is usually flagged by O2 data and/or fuel trim data, I'm not fluent in the logic behind fault on this car. Both of those codes would point me in the direction of the fuel pump and testing it. A clogged fuel filter makes the pump work harder and leads to pump burn out, so make sure that's been serviced. If you have access to fuel trim data you should always be rich at wide open throttle.
Hope this helps
Hope this helps
Added part number to title for search
By the way
$200 for the Volvo one, $44 for the Bosch one from FCP - good price from Rock Auto above!
Probably a good junkyard part to scavenge too.
By the way
- 2027 Views
Last post by pgill
- 20 Replies
- 3870 Views
- 1938 Views
Last post by bfry
- 344 Views
Last post by dmcfan
- 2863 Views
Last post by Pretribrapper
