Replacing A/C Compressor
Third generation Volvo V70 wagon and XC70, and second generation S80. Are you an owner? Prospective owner? Get in here and join us! Start a new topic or comment on an existing thread.
2008-2016 V70
2008-2016 XC70
2007-2016 S80
volvooh
Year and Model: '98 S70, '05&'08 V70
Been thanked: 4 times
Post by volvooh »
2008 Volvo V70, 156,xxx mi. I purchased the vehicle knowing I would need to replace the compressor, makes a noise that sounds like rattling spoons. How is the serpentine belt relaxed to facilitate removal? Also, where is the A/C dryer located? Makes sense to replace this as well if I am going to the effort of the compressor.
Has thanked: 1507 times
Been thanked: 3822 times
Not an expert on the 2008s but I expect the drier is mounted on the condenser like the P2s - unlike the P80s with the big coffee can near the frame member. Look for an aluminum soda can size thing or a skinny tube thing near the condenser?
Screen Shot 2019-05-29 at 10.18.08 AM.png (201.46 KiB) Viewed 1430 times
pgill
Year and Model: 2010 S80, 2008 LR2
Has thanked: 115 times
Been thanked: 185 times
Post by pgill »
Volvooh,
For my 2010 S80 3.2 the dryer is a desiccant bag inside the condenser.
It comes in a sealed aluminium Mylar bag and it only has a 1 year shelf life.
Don't open the Mylar Bag until you are ready to install the desiccant in the condenser.
The cap that holds the bag in place uses a Torx T-70 fastener.
I didn't check but I would think that the V70 uses the same configuration
This is what I bought
GENUINE VOLVO 30776238 Receiver Drier Insert
If I had to do it again I would also replace the plastic cap witht he O-rings and filter screen at the same time (I don't have the part number handy)
Note: to replace the desiccant bag you need to lift the radiator and Fan and then lower the cross-member under the radiator. This will expose the plastic cap with the T-70 that needs to be removed. Also don't forget to remove the R134a first.
Good Luck
Paul
P.S. I ended up replacing the AC compressor also and now it blows really cold
pgill
Post by pgill »
Item #2 and #3
These are what I would replace
To remove the old bag you just need needle nose pliers or small fingers
The Bag fits inside the condenser, picture not to scale.
