1996 850 GLT OXS readiness on/off, inspection, intermittent CEL zionx thread from WDYDTYVT diary
Been thanked: 4065 times
lets try to find the 1996 electrical diagram and post it up and hash it through.
(Ive promised Volvo I won't post these as a mod, but you can do it.)
ZionXIX
Has thanked: 66 times
Been thanked: 195 times
Post by ZionXIX »
All data shows this diagram for the fan cooling relay. I appears that 1 line comes directly from the positive battery terminal and 2 lines make their way to the ECU and it looks like there is a a bypass in the relay itself to the ecu. Picture from all data.
ZionXIX
Post by ZionXIX »
Full pdf print out
Print….pdf
(126.81 KiB) Downloaded 107 times
Monitor yellow wire on ECM, pin 22, to see if 12V is broken when you key off. I don't see how that could happen, but thats how you diagnose, one step at a time
ZionXIX
Post by ZionXIX »
Well the plot thickens. Backprobed the yellow and yellow white wires on the cooling fan relay and got 12v with key off. Pulled the ecu and found pin A22 and measured 12volts with key in all positions and off. So the ECU has power at all times. I have no idea why it has alzheimers.
bmdubya1198
Year and Model: 2K V70R M56
Has thanked: 316 times
Been thanked: 531 times
Post by bmdubya1198 »
Just be careful probing ECU pins like that. They can get damaged very easily!
ZionXIX
Post by ZionXIX »
bmdubya1198 wrote: 16 Jul 2019, 18:02 Just be careful probing ECU pins like that. They can get damaged very easily!
I was nice and gentle....I only used the tip of the probe
You got B+ voltage right? Battery voltage to nearest 0.1V ?
Check voltage at Fuse 11/1 and then at pin A12 on the ECU for same voltage reading, to nearest 0,1V
Check pin A26 for battery voltage to nearest 0.1V
ZionXIX
Post by ZionXIX »
Where is fuse 11/1?
