ECM Issue?
RuinedS80
Year and Model: 2001 S80 T6
ECM Issue?
Post by RuinedS80 »
Hi all,
I have a 2001 S80 T6 with the P0238 trouble code. The car stopped running while driving on the highway and would present a crank and no-start issue. When inspecting the car, I noticed that one of the o2 sensor wires had been dragging on the ground and was subsequently sheared and broken. Could this have caused a short and fried the ECM? The code points to a potential MAP sensor issue but I doubt that a faulty MAP would cause the car to shut off and not start again. Any help is appreciated. Thank you.
projectsmorol
Year and Model: 2008 c30
Post by projectsmorol »
Replace the MAP sensor.
2008 C30:
Darton wet sleeves|CP Carrillo pistons&rods|Upgraded injectors|K16 turbo|3"downpipe|ELEVATE:cat back|custom intake|turbo intercooler hard pipe|lower motor mount|turbo blanket|intake plenum|downpipe wrap|dual bypass valve|lowering springs|rear camber arms|do88 FMIC|Porche 70mm TB|BMC air filter|MAF upgrade|Turbosmart waste gate|meth injection|IPD brake lines|NGK iridium 1 step colder|APR head studs|AEM AFR/Boost Gauge|Hilton Tuning
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
RuinedS80 wrote: 27 Jul 2019, 14:09 I noticed that one of the o2 sensor wires had been dragging on the ground and was subsequently sheared and broken. Could this have caused a short and fried the ECM?
Fix and Plug back in before going down the rabbit hole. When I was at Acura the same thing happened on a new car I PDI'ed. Plumes of smoke and dies. Found the wire hanging under the car. Plugged back in and had no issues. Don't remember clearing codes. Back in the day we entry level guys counted red flashes to retrieve the codes.
Has thanked: 1506 times
Been thanked: 3822 times
RuinedS80 wrote: 27 Jul 2019, 14:09 Hi all,
You could have blown a fuse from the heater circuit from a short so trace and fix that fault, though. It’s never the ECM
