How many drain and fills ?
- GlennG2759
- Year and Model: 2006 V70 NA
- Has thanked: 112 times
- Been thanked: 17 times
2006 V70 NA new to me 100,500 miles. Vehicle shifts fine.Trying to do the math. How many drain and fills do I have to do to get to relatively fresh fluid. First took 3.5 qts.(very dark). What is the recommended mileage in between drain and fills? Thanks
- MoVolvos
- Has thanked: 310 times
- Been thanked: 524 times
There are some who fear changing the fluid all at once regardless of method
This is what you are considering doing. Some however do this over a period of weeks between each.
Many here just do it all at once.
- Been thanked: 472 times
Check to be sure but total fill from factory (from a dry system) is about 8.1 quarts.
For a simply drain and refill, it is about 3.5 quarts.
Just use the principle of "half-life" or dilution ratio and do the math.
I wrote a DIY ATF fluid for XC90 a while ago...
viewtopic.php?f=10&p=514720
- SuperHerman
- Been thanked: 207 times
Were it me I would do a drain and fill, drive it for a day or two and then do another drain and fill. After that just do a drain and fill every two or three oil changes.
daughtersmechanic
- Year and Model: 2001 V70 XC
According to my math, 4 changes will get you to 90% new fluid.
1-- 43.75%
2-- 68.35%
3-- 82.20%
4-- 89.98%
This assumes that the new fluid is fully mixed in with the old.
Of course, after the second drain, you're replacing more new fluid than old, so factor that in to your 'is it worth it?' calculation.
You're a clean freak, you say? You want 99% new? That'll take 8 changes (98.9977%)
1-- 43.75%
2-- 68.35%
3-- 82.20%
4-- 89.98%
2001 XC70, The Beast, 222K
- MoVolvos
I think if I were to put in a filter I would install a "Y" so it is only filtering a portion. Not sure how much the filter reduces the pressure or if there were ever a major issue with the transmission it would be plugged up?
I purchased quite of few of the Magnefine filters years ago during a sale but never got around to installing them. One was for a 98 S70 T5 which seem to get dirty pretty quickly.
- Has thanked: 1506 times
- Been thanked: 3822 times
Ive tried Gibbons and they just don't get the work done on time..
- Screen Shot 2019-08-05 at 4.14.34 PM.png (289.07 KiB) Viewed 3417 times
- 590 Views
Last post by rguzz
- 565 Views
Last post by lingon300k
