So my xc70 2004 180,000mil i bought needs an oil change.
former owner extensive records show only regular oil change and 6 months intervals.
IPD recommended and sold me semi synthetic.
https://www.ipdusa.com/products/11929/1 ... kit-125420
ive read a lot to about synthetic causing leaks when switching from regular.
is that true ?
Switching to synthetic oil...
- June
- Has thanked: 523 times
- Been thanked: 261 times
No you should not have trouble. June
My Volvo cars owned
1989 740 GLT ordered
1996 960 ordered
1998 V70 GT dealer stock car
2002 S80 T6 ordered totalled
1996 960 ordered
- oragex
- Year and Model: S60 2003
- Has thanked: 102 times
- Been thanked: 352 times
It depends, was the car run on mineral (non synthetic) before ? If so you should be careful at 180k miles. I give a few tips here www.youtube.com/watch?v=IGU-f1MA-VY
93SCMax
- Year and Model: 2001 V70 T5 mt
- Has thanked: 36 times
- Been thanked: 44 times
If it were my new (used) car, at 180k, I'd stick with dino oil. If she isn't leaking oil (?) with dino, why chance it now?
All my cars run Mobil 1 5W30 or 10W30 synthetic, but started using the synthetic at the 1st oil change. I'm a fan of synthetic but believe switching late in an engine's life could be problematic with seals and "loosening" gunk.
Georgeandkira
- Year and Model: '07 V70 + '15 XC70
- Has thanked: 64 times
- Been thanked: 69 times
Since it was serviced regularly there shouldn't be any globs of sludge in it.
Also, given that all this stuff has improved immeasurably over the life of this car AND that you don't live in Death Valley or the North Pole, sticking with a good quality (no bargain weirdo brands) conventional would be OK.
What would be good to do is servicing of the PCV system. If the box and passages are plugged with crud you'd then know what to focus on.
- Rattnalle
- Has thanked: 20 times
- Been thanked: 133 times
I'll go with the "there won't be an issue"-camp. Any issues could just as well be caused by using a higher detergent dino oil. But such issues are symptoms of an engine that's already shot and will go soon regardless.
Perhaps throw in an extra filter change after a few k, then you'll see if there's stuff coming loose or not. I've had some extra stuff there sometimes when switching oil brands with the same classification. Probably different amounts of detergents in them.
- Rattnalle
We haven't had dino oil around for ages anyhow. But the lowest OK spec is ACEA A1 which is really old so they're not that picky really. Unless you've got a turbo and drive it hard.
- Has thanked: 1498 times
- Been thanked: 3810 times
No dumb questions here, Katten
Every turbo car should run synthetic, and most NA cars also should run synthetic. It’s just better stuff.
The longer drain interval justifies the higher price , not even counting the labor
